Grading What works a tractor harder?
/ What works a tractor harder? #21
I like the way you're thinking. It's a machine, make it work. :thumbsup:
Having said that, I find I have an easier time using all my tractor's power with ground engaging stuff, like a land plane filled with rocks, than I do with a finish mower. With a mower I often have to go slower to get a decent cut or to make the turns.
Yeah, undersized mower or thin or short grass will foil it. But thick grass a foot or more high can easily consume 10HP per foot of mower width at about 4mph.
Surprised me on my 2010 JD one time using a 5' bushog. ... I had zinged thru a bunch of little trees ~2" and then hit grass. Thot id messed up the tractor!
/ What works a tractor harder? #22
As said earlier, both tilling and mowing take exactly the same power.
Running at full rpm doesn't mean you are producing full power. You are running at full rpm with both implements, but you are working way longer per acre with the tiller.
/ What works a tractor harder? #23
You are running at full power with both implements, but you are working way longer per acre with the tiller.
Yeah. More energy, work, per acre.
/ What works a tractor harder? #24
Everything takes the same power given equal loading.
Not crazy about running a tractor at full load. I guess I've watched too many tractor pulls where at all out they bust up. I'm more in favor of 2/3 to 3/4 load. Not that I should compare to a tractor pull, but just sayin'
/ What works a tractor harder? #25
Everything takes the same power given equal loading. Not crazy about running a tractor at full load. I guess I've watched too many tractor pulls where at all out they bust up. I'm more in favor of 2/3 to 3/4 load. Not that I should compare to a tractor pull, nut just sayin'
Tractor pulling tractors are putting out like 1500% of full power of the "stock" engine. Running a stock tractor at pto rpm doesn't hurt anything.
/ What works a tractor harder? #26
Yep. That's why I said "Not that I should compare to a tractor pull, but just sayin' "
But I still don't like running full power often. Just my $0.02
/ What works a tractor harder? #27
I'll tell you a good test and you well see what takes more HP. Take a tiller and back it into a creek like you are going to clean it, then do the same with the bush hog. I guess that is why it's called a hog, a hog on HP.
/ What works a tractor harder? #28
While you're at it why don't you run over 200 feet of 1/2 cable with both.
/ What works a tractor harder? #29
Takes a lot of hp to stir water that fast. That test doesnt show anything relative to the design tasks.
/ What works a tractor harder? #30
Yep. That's why I said "Not that I should compare to a tractor pull, but just sayin' " But I still don't like running full power often. Just my $0.02
I don't either. My tractor doesn't reach pto 540 until 2700 rpm. I like to run about 2300 for mowing, and about 2000 for just piddling around.
/ What works a tractor harder? #31
I know kind of an old thread but the guys saying it takes the same are correct from my experience. I can kill a tractor mowing or tilling. All depends on the ground speed, depth your tilling, what your tilling, thickness of grass, type of grass. RPM is dictated by all of those variables. This is a "It depends" question that cannot be really answered.
/ What works a tractor harder? #32
I have to disagree with most of the guys here. When tilling, you are going so slow that the tiller is not really engaging the tractor in a pulling contest or PTO HP contest. The blades turn so fast that mostly they are just remixing the soil with just a bit of new dirt being chopped in at each turn. Going faster only makes the tiller come out of the ground so it really doesn't load my tractor any more going faster vs slower. I cant even tell when my tiller is engaged by looking at the RPM but I sure can when engaging the bush hog. I can stall the engine bush hogging if I go too fast in super tough conditions but cant see any stalling in the tiller regardless of speed of travel.
Pulling a disc harrow is more conducive to stalling and more of a comparison to the bush hog for power needed to operate.
/ What works a tractor harder? #33
Running at full rpm doesn't mean you are producing full power. You are running at full power with both implements, but you are working way longer per acre with the tiller.
Running at full rpm doesn't mean you are producing full power. You are running at full rpm with both implements, but you are working way longer per acre with the tiller. ,,,:confused2:...
,,,,,,,,,,,,,,Unfortunately, after I answered the original incohesive post you edited it into incoherence.
/ What works a tractor harder? #34
If your going too fast and your tiller is coming out of the ground your not really tilling (or at least not like you want to). That would be like saying your mowing two foot grass but your only cutting off half way down so you could go faster at that too but you wouldn't be cutting it like you want to. It's still mostly about ground speed. Pulling a ground engaging non rotary implement wasn't in the original comparison posted but I do agree with you that can take a TON of HP depending on the variables.
/ What works a tractor harder? #35
You have a special case where there is surplus hp ... or a tiller that is too small or light in weight.
/ What works a tractor harder? #36
I run a 6" tiller on my 35 HP tractor.
If I'm tilling previously tilled area I till with ease.
If I'm tilling full depth in an untilled area it will take most all the power I have.
/ What works a tractor harder? #37
Lets get back to basics: It takes a certain amount of Energy to do a task.
Let's say it's pulling a log up a hill. Doesn't matter if you're using a 10 hp garden tractor (assuming traction) geared down so low that it takes 20 minutes, or a 200 hp skidder that takes 1 minute. The "energy" both machines delivered is the same, only the rate (time required) differs.
Horsepower is a measure of the RATE (I.e. speed) of applying that energy.
When people ask how much horsepower do I need to do a task (snowblowing, tilling, mowing etc...) it's sort of the wrong question.
Because the answer is ALWAYS another question: Well, how fast do you want to go?"
/ What works a tractor harder? #38
,,,,,,:thumbsup: ... Now the blanks are all filled in. ;)
/ What works a tractor harder? #39
You mean something like this:
https://www.youtube.com/watch?v=13Yz_KCEN8M
/ What works a tractor harder? #40
Pretty much the way I see it^^^^^^
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A63688)
2023 New Holland...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
2015 Jeep Patriot Sport SUV (A61574)
2015 Jeep Patriot...
2004 Chevrolet Silverado 1500 Pickup Truck (A61573)
2004 Chevrolet...
