Hydrolics
/ Hydrolics #2
help us help you.. any backstory on this?
is it a mechanical problem like a bend cyl rod or damaged loader frame that physically won't let it lower?
if not that, have you tried running hte spool thru range of motion with engine off and letting it exhaust?
Have you thrown a towel over the line fromt he spool to the lift cyls and then cracked the connector with a wrench to see if it starts leaking and lowering the loader?
tell us what you have, and what you have already done.
pics help.
/ Hydrolics
Started slowing on downward motion the last few times I used it. Now will not lower at all. Seems the control leaver does not want to push forward. Have not tried bleeding lines. All other motions work ok.
/ Hydrolics #4
With so little info start here, take the cover off at the of spool and see if anything is broken or came loose. With cover off the spool should move easy.
/ Hydrolics #5
so.. it won't lower because the spool won't move???
investigate the spool!
/ Hydrolics #6
Won t move because sistemefilter orifis is blocked . THAT IS THE VERY LITTLE FILTER IN THE MIDDLE OF THE FRONTHOUSING .
/ Hydrolics #7
Mahindra loader stuck in up position
It could be stuck due to mechanical issue.
If the spool can not move, then the loader should not move.
If the return hose is blocked, the loader will not lower.
Another valve might be causing some back pressure.
Check the position of the 3pt lever . It should be in neutral.
Does your valve have a lock position.
Reset your QD's if you have them
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
New Carbon Steel 4.75-12T Shackles, 38 Total (A62679)
New Carbon Steel...
Peanut Wagon (A64127)
1997 Titan Gooseneck Trailer (A66285)
1997 Titan...
2008 Kaufman Wedge Trailer (A62613)
2008 Kaufman Wedge...
