How Not To Take Care Of Your Tires
/ How Not To Take Care Of Your Tires #31
Right now my tires in the front are new. If I measure to the center line of the wheel I have a diameter of 27" diameter. With that diameter my wheel has a circumference of about 84 inches. If I travel ten revolutions of the tire I cover 840".
Now lets "wear" an inch off the tread. This changes the diameter of the tire to 25". The wheel now travels 25 x 3.14152 inches or 78" per revolution. Ten rotations now covers 780".
The connection between the front axle and the back axle is "locked" when in 4wd. That being said, the drive shaft into the front axle must match the rotation of the rear axle. If both connections are rotating at the same speed then the engage/disengage is a easy task. Now imagine the front axle with the 1" or wear on the tires. The front wheels are now rotating faster to cover the original design (new tires) of 840". The rear tire size has not changed any appreciable amount (fronts wear out way faster than rears). This causes a mismatch of the rotation speeds where the front axle meshes with the rear axle thus a bind is felt when shifting.
You can travel in 4wd all the time but as the front tires wear the ratio becomes more of a mismatch. when locked in 4wd this "mismatch" of turning must be accounted for. Since gears can't "slip", the only place that the "slip" can occur is at the contact with the ground. With the rears being heavier than the fronts, the fronts are forced to make up the mismatch by sliding on the ground slightly, this sliding accelerates the wear of the front tires thus accelerating the change in the diameter.
I am sure we are both on the same page that this all comes down to is get your tractor out of 4WD unless you need 4WD and keep your tires inflated fully, especially as they get shorter. By all means get it out of 4WD when you have a heavy load in the bucket on a solid surface where the front tires cannot "slip" as would happen on gravel.
Hope this makes some sense John. I suspect we are on the same page just a different language. :)
Gregg
OK Gregg, I have a question. My L4400's fronts are about worn out and I am having trouble shifting out of 4WD. Wouldn't the rear tire wear compensate for the fronts wearing, after all, they're wearing too..
While we're at it, is there any tires that wear better as replacements? The OEM tires are Titan II, and at $177 a piece, I'm looking for something more economical..
Thanks!
Dave
/ How Not To Take Care Of Your Tires #32
Thanks!
Dave
My rears are filled so they are much heavier than the fronts so I suspect the slip happens in the fronts. Also, if you wore an inch off your rears it would be a much smaller percentage of tire radius lost. I have to replace my fronts due to wear probably at a three or four to one ration with the rears. The amount of rubber (square inches) in contact with the ground is significantly greater on the rears than the fronts as well.
As for which tires wear best, I have yet to be able to discern any difference by manufacturer. All I know is that my driveway should be softer due to all the rubber I have left on it... :) The last ones I put on the fronts I got from Nebraska Tire. I ordered tubes as well. Since the hole where the stem comes through was rusted, they had a little boot that protected the tubes from the rim as well.
/ How Not To Take Care Of Your Tires #33
Does the BX leakage occur with stock as well as aftermarket brand tires?
/ How Not To Take Care Of Your Tires #34
Thanks!
Dave
I see lots of tires used and abused and it's universally accepted that Firestones are the best. I have had the most difficulties with Titans and I only buy them when there is no size alternative.
/ How Not To Take Care Of Your Tires #35
I noticed one of my BX front tires was flat a couple weeks ago...lifted the front with the bucket and slimed the tire. Was okay until I was putting on my backhoe and when I turned to come back from the rear of the garage where my concrete slab is, and felt the dreaded drag of the front wheel again. This time the tire was wobbling on the rim with a broken bead...luckily, I lifted it and brought my compressor out and was able to "pop" (it literally, went POP twice while inflating as the bead and once again sealed.) Now I don't trust it even though it has held air for a good week now.
I am going to go the tube route and forget about it! Calling my dealer now.
/ How Not To Take Care Of Your Tires #36
Picked up my 10 month old, 40 hour front BX tire from the dealership today. $34 to tube it. I just remembered that when I trailered the BX25 home last December the tire was flat and I had to air up before unloading from the trailer, so this has been happening since day one. On mine, it never seemed to get low, it was with Ok or flat every few weeks. I would check the pressure every few days and it would be ok, then next time, flat.
/ How Not To Take Care Of Your Tires #37
Yes my leaks were with the original stock tires right out of the gate. I recommend tubing them from the start. I'm not a fan of sliming but I know many are okay with that approach.
/ How Not To Take Care Of Your Tires #38
I like tubes... just can't buy them anywhere local or have them put in at the tire shops... might be the area where the tractor is located.
Figured by the time I found some online and had them shipped and then installed... I would be losing too much of my vacation time waiting.
All things equal... tube would be the better choice and they can be patched too.
/ How Not To Take Care Of Your Tires #39
Really??? Les Schwab... while you wait. 'least round here.
/ How Not To Take Care Of Your Tires #40
Closest one is about 35 miles away...
I went there to buy two tubes for my box utility trailer and learned they didn't have any... recommended buying two new tires.
I also took my BX23 rear tire to the Goodyear truck center as they said they repair tires... said I would have to leave it and I did... after 3 days they said they don't repair off-road tires...
Ended up driving 90 miles to Stockton California to a AG tire place and had both rears foamed filled and worth every penny.
I have heard explanations from liability to profitability.
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
2006 GMC C5500 BUCKET TRUCK (A59906)
2006 GMC C5500...
2023 GMC Seirra Elevation Crew Cab 4X4 Pick-up Truck (A60352)
2023 GMC Seirra...
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
