Calcium filled tires… Same pressure test?
   / Calcium filled tires… Same pressure test? #11
You could get lucky getting years of trouble free service BUT your steel wheels will be ate slam up with RUST.
I AVOID that stuff at all cost & I have 16 tires on the farm that is fluid filled.
Tires I have on my New Holland are filled with methanol and water mix. Lose some weight but non- corrosive on wheels. Had a 53 Super A on farm that had a leak in tube. Calcium eat the wheel and tube started protruding through wheel. Had to weld steel plates on wheel when we put new tires on. Beet juice is non-corrosive on wheels also I am told
   / Calcium filled tires… Same pressure test? #12
Most everyone believes Michelin Tire Company about air pressure.
I run 18psi in fluid-filled rears, which is a bit much for field work IMO. Many run 12psi for field work, but it depends upon your tractor weight, tire weight capacity, and implement weight on 3-pt hitch.
EDIT: I checked my R1 Goodyears today. I was wrong, the man that put the WW fluid in them set my air pressure to 12psi.
Hum, the tires still have no bulge in the sidewalls.
   / Calcium filled tires… Same pressure test? #13
Mine will seep water / AF mix between rim & tire sometimes IF below 20psi
I run front & rear fluid filled on all 3 of my JD tractors for traction on my steep banks & hills.
Makes a world of difference too in chicken houses running the caking machine.
Better steering response too with a heavy 3pt implement attached.
   / Calcium filled tires… Same pressure test? #14
Mine are around 15 psi or lower in the rear, a bit higher in the fronts and tire max in the fronts when doing a lot of loader work.
   / Calcium filled tires… Same pressure test? #15
Both my tractors are filled with CC front and rear. When I check pressures even with the Schrader at 12 o'clock and purge the stem of liquid (if it even still works) I get some liquid in the tire gauge which ruins them. So I watch for them on sale and buy a handful of the extending stem tools when cheap. Then I check them against a non-filled tire with a known good gauge (low pressure with a round face gauge) to see if each one is reasonably trustworthy. After checking all the filled tires since I have the hose out anyway I throw the stem gauge in the trash because after it sits it will not be trustworthy for the next time.
2012 Vantage P-42-1000 42ft. T/A Dry Bulk Pneumatic Tank Trailer (A55973)
2012 Vantage...
HUSQVARNA CHAINSAW & BLOWER (A58374)
HUSQVARNA CHAINSAW...
NEW Long Forks (A59000)
NEW Long Forks...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
(2) POLY ROLLING CARTS & CONTENTS (A58374)
(2) POLY ROLLING...
2018 SkyJack SJ1056TH 10,000LB 4x4 Rough Terrain Telehandler (A55973)
2018 SkyJack...
