Bought a new snow bucket...
/ Bought a new snow bucket... #1
Lunk
WI
Branson 4720H / BL200 Loader
Ordered it yesterday from Jenkins Iron & Steel out of Minnesota.
6 footer for my 35hp TYM.
www.jenkinsironandsteel.com
Free shipping included, and it was priced $600 less than a locally sold bucket made by the QuickAttach folks.
Dealt with Adam, and he proved to be a real joy to work with.
I will post a couple pics when it arrives in 8-10 days.
Lunk
/ Bought a new snow bucket... #2
Hard to believe not that far off old man winter will be knocking once again.
/ Bought a new snow bucket... #3
Let us know what the fit and finish is like. Im considering their stump grapple but can't find much info on the company. They started selling on Craigslist here.
Will do...Seems to have enough steel in it for sure...
Lunk
Well it arrived today, and appears to be all I'd hoped for!
Very well made, and fit and finish are A-OK
Check out the pics!
/ Bought a new snow bucket... #6
Lunk, I'm curious what the advantages are of the snow bucket over your stock bucket. Is there that much more capacity? Stock on your loader is 10.4 cu/ft, I think.
/ Bought a new snow bucket... #7
Nice bucket Lunk. I've never really liked the puny buckets that most CUTs have. And for snow removal they are pitiful. That bucket in the pictures looks like it will do the job and save tons of time. What is your lift capacity on that tractor and what does that bucket weigh?
Threepoint, I recently bought a 6 foot snow bucket from Lofland Fabrication. My bucket does not have as high a back as Lunk's, and mine has a 27 cu foot capacity. Lunk's bucket is probably around 30 cubic feet.
Picture of the one I just got.
/ Bought a new snow bucket... #9
I wonder what those "holes" that are on the top back are for.
/ Bought a new snow bucket... #11
It's just the weight and abrasion of snow vs. gravel/dirt/rock. Same power can move a lot more snow, but the standard bucket is sized for summer work. Snow bucket or pusher/plow etc can be a lot lighter construction also and still get the job done. No way that tractor could move that bucket if it was filled with gravel. Similar with plows - a pickup truck can push a snow plow of a size that would require a serious dozer in dirt.
/ Bought a new snow bucket... #12
/ Bought a new snow bucket... #13
/ Bought a new snow bucket... #14
... Snow bucket or pusher/plow etc can be a lot lighter construction also and still get the job done...
I just want to comment that "light" construction vs "standard" or "heavy" construction is all relative. I don't know about your snow bucket. My snow bucket weighs ~500 which is roughly twice what my "standard" OEM bucket weighs. The snow bucket has a much thicker cutting edge (3/4" x 6") than the standard bucket (1/2" x 4"). It has more reinforcement. There is really no comparison in the construction. The snow bucket is built much stronger yet the manufacturer calls it "light" construction. This is because these are made to withstand 70hp skid steers and they are comparing them to the heavy duty digging buckets that type of equipment requires. My point is that nobody buying one of these for a CUT should consider them "light" in construction or in terms of how the bucket weight affects your lift capacity.
I'm really anxious to try mine in snow. I think it is going to work great and save met a lot of time but I won't know for sure until it snows - of course it is also great for moving all those things that wont fit in a standard bucket (gas grill, large trash cans, lots of firewood and anything else that is "light")
I will definitely be using mine for firewood. I try to fit as much firewood as possible in my stock bucket but it is a balancing act as you can see from the picture below.
For those considering one of these, just be aware of the extra bucket weight, the impact of the extra bucket length on your loader (especially the curl function), and that with a high volume bucket you can get a lot of weight in there fast.
The new bucket is just 6" wider than stock, but has about 3 times the capacity. It works a lot like a pusher in that respect, with the added benefit of the attributes of a bucket. I also use it for clean-up of lighter materials around the homestead. You can fit a lot of crap in it for sure!
The new bucket has about 3 times the capacity as stock. It acts much like a push-box in that respect, with the added benefit of being a bucket.
I also use it for collection of lighter material around the homestead.
View attachment 441703View attachment 441704
The weight is just over 600#. Lift capacity is around 2200# IIRC.
What he said.
Sides and back are 3/16" steel. Wear strips on bottom and gussets on back of bucket are 1/2" steel.
Yes. Holes are for visibility, but from a skid-steer cab IMHO.
/ Bought a new snow bucket... #19
Interesting thread... but Gladehound, surely you don't really move a stack of firewood like that in the photo... I don't think I could get 20' before it was falling all over the place- even in L speed.
/ Bought a new snow bucket... #20
I did drive with it. Only ~150 feet from my splitting area to the wood shed. Did not drop a single piece. I was going about 1.1 - 1.5 mph but it never felt like the pile would spill. I did this because my log splitter doesn't have an off switch so I keep stacking (if I can) until it runs out of gas. I rarely can get it all stacked in one bucket trip. The stack usually starts to get unstable and I then throwing the splits on the ground and make 2 trips. But a few times I've been able to just keep stacking it and it felt real solid so I just went with it. With the new bucket, I'll never have to throw split wood on the ground so I can eliminate all the bending over to pick it up again! :thumbsup:
2022 LIUGONG CLG922E EXCAVATOR (A63569)
2022 LIUGONG...
Informational Lot - Shipping (A63118)
Informational Lot...
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A64194)
2004 International...
2016 Ford F-250 Warner Service Truck (A61573)
2016 Ford F-250...
JOHN BLUE 4-WHEEL WAGON GEAR (A63290)
JOHN BLUE 4-WHEEL...
2015 International WorkStar 7500 T/A Dump Truck (A61573)
2015 International...
