Rims Hub centre question
/ Hub centre question #1
LondonDave
Melbourne, Ontario Canada
John Deere 5410 MFWD, Case IH 5230 MFWD
I'm looking at a used set of rims and tires for the 93 Ford 3930. My hub centres are 5.5" and the ones I'm looking at are 6". The bolt spacing is the same. Will these work with the larger hub spacing?
Thanks
Dave
/ Hub centre question #2
It depends if your wheels are hub pilot type or not. With hub pilot type the wheel is centered and supported by the center hub, the nuts / bolts usually have a flat head against the wheel and just hold the wheel on.
If your nuts / bolts have tapered head (like automotive style wheels) the tapered nut / bolt center the wheel and hold it on.
If your current wheels are the latter the ones with the 6" center will work if the bolt pattern is the same.
Ok. Makes sense. Thanks. I'll check the bolts on my current set up.
2014 FREIGHTLINER 108SD CONCRETE MIXER TRUCK (A59823)
2014 FREIGHTLINER...
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
2022 Case SV280 (A60462)
2022 Case SV280...
John Deere 1025R (A53317)
John Deere 1025R...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
10 Safety Systems Barricades (A59317)
10 Safety Systems...
