Help...shoudnt the tires spin ???
/ Help...shoudnt the tires spin ??? #71
I remember spinning 3 tires on my last tractor ( the Kubota) in LO range on Asphalt when trying to pull over a tree. I haven't tried it with the Kioti. Both have R4's, both 3 speed Hydro's, This included rear ballast, and a downhill pull.. Any hydro should be able to spin tires in LO range. Med, may be iffy, depending on many factors, and HI is no way. At least that is been my experience.
/ Help...shoudnt the tires spin ??? #72
I don't care how much faster a gear tractor can spin the wheels I'll take a HST every time.
yup,
and with my HST with FEL, BH and loaded tires, I always break traction. I've never noticed a relief valve kick in. I'm running about 2 1/2 times naked weight.
/ Help...shoudnt the tires spin ??? #73
Did that gear tractor have a rather high 1st gear, or the conventional 1 to 1.5 mph? All the ones Iv ever encountered with the 1.5 low will hold a spin at about 1K engine speed. That would be about 0.6 mph wheel rate.
I have had Kubota L2550DTs that would bog the engine rather than spin tires on dirt just soft enough for the
AGs to bite deeply. This was with a backhoe mounted and using the FEL to push into a giant pile. On pavement,
which is not as good of a surface, I could always spin them.
This tractor has a very low 1st gear.
Another Kubota, this time an HST B21, would bog the engine in Low range even with R4s. Hoe mounted. The
B21 is very low on power, and, as they get older, they often have less hp. This one had 2400 hours. Note
that not all tractors as they age lose power. If rings/cyl get worn they might lose some compression (less hp),
but they also loosen up and have less internal friction losses.
Once you break loose the tires, less power and force is needed to maintain (or speed up) the spin.
Those with gear tractors pushing their FEL into a huge pile of materials should avoid feathering
the clutch to increase torque to the rear wheels. Clutches are a huge job to replace....I
just did one on an L2550.
/ Help...shoudnt the tires spin ??? #74
yup, and with my HST with FEL, BH and loaded tires, I always break traction. I've never noticed a relief valve kick in. I'm running about 2 1/2 times naked weight.
Me too. Naked weight is 3,139 with everything on it it weighs 8,500. The only time I couldn't break traction was when I failed to release the parking brake. With the backhoe removed I can break traction in medium.
/ Help...shoudnt the tires spin ??? #76
Thats pretty amazing. Our L2550 with loaded AG tires, 1500# power brush as counter weight, and the loader carrying all it will pick up, will spin 4wd with diff locked effortlessly in low range 1st at low idle. The engine barely loads.
,,, 1st is very low as you said - it tops out at under a mph. I only use it to go/spin as slow as possible ... about 1/3 mph so I dont have to feather the clutch ;). The lowest I ever go for max tractive force available is low range 3rd.
/ Help...shoudnt the tires spin ??? #77
I have had Kubota L2550DTs that would bog the engine rather than spin tires on dirt just soft enough for the AGs to bite deeply. This was with a backhoe mounted and using the FEL to push into a giant pile
Yours must be defective. My Grandpa used to have one. It had a loader, loaded R1 tires and a backhoe. It would effortlessly spin the wheels on dirt with the engine idling. With the engine turning about 2500 rpm it would slip the wheels in 5th gear.
/ Help...shoudnt the tires spin ??? #78
Well, that matches mine on the low end. Fifth/hi range1st gear however can easily be over ridden by good traction conditions.
/ Help...shoudnt the tires spin ??? #79
"Stuff" includes pump and hyd motor that, due to the automatic protection relief, have been designed close to the original specific torque point.
A gear typically has a large performance margin to start with. Try nearly tripling the weight of an HST tractor and see if it will spin the wheels with AGs on good ground. A gear will.
Sure. My point is that a lower capability may be TYPICAL of production hst tractors, but it isn't INHERENT in the design of hst systems. An hst system can be designed to deliver whatever torque delivery specifications you might request. It is incorrect to generalize that hst systems have some inherent deficiency that prevents them from ever matching the torque delivery of a geared system.
/ Help...shoudnt the tires spin ??? #80
I don't think so. My 1st tractor was an '89 L2550DT, purchased along with 2 others
from a rental company. I still know where 2 of them are, owned by friends. One
has a hoe on it.
It is not as easy as you might think to duplicate ideal traction conditions. High
weight plus soil that allows the deep AG lugs to fully embed, front and rear.
Simultaneously pushing into an immovable pile, and lifting with the FEL at the
same time.
Of course, lifting at the same time as pushing does use some of the engine's
power, which takes away from motive power.
I could never bog any of the L2550s without the hoe mounted or on pavement.
Never. Always spin the tires.
Finally, this is a pre-EPA tractor with about 2000hr, and all 3 had significant
blow-by, readily visible from the hose that hangs at the bottom of the engine.
Clearly, less power was available vs. new.
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
2014 Ag Spray Schaben Sidedresser (A56438)
2014 Ag Spray...
Kubota MX5400 land mgmt package
Kubota MX5400 land...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59906)
2016 FREIGHTLINER...
2025 MMS MS36CJ (A60463)
2025 MMS MS36CJ...
