SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,530
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
"Stuff" includes pump and hyd motor that, due to the automatic protection relief, have been designed close to the original specific torque point.But I want to point out that this is not an INHERENT limitation of HST. Beef up all your hoses and fittings and stuff, set the relief higher, and you could snap an axle off the same as you could by abusing a geared tractor. If you engineer the drive train of a geared tractor just barely strong enough that it won't be broken by sudden, full-stop traction against its engine running at full tilt...and you design the HST system of its otherwise twin brother to relieve just before breaking the other drive train components also, then they could put exactly the same maximum torque to the ground.
As you imply, we implement the relief because we don't want users approaching and exceeding the limit without feedback. So instead of suggesting that HST systems are deficient, what you're really saying is that both can put the maximum safe reliable torque to the ground, but that a geared tractor will let you go beyond that and break it if you want. To CobyRupert I'd say I'll take the infinitely variable ratio and the built-in protection, thanks.
A gear typically has a large performance margin to start with. Try nearly tripling the weight of an HST tractor and see if it will spin the wheels with AGs on good ground. A gear will.
