Buying Advice Confused
/ Confused #1
swistur
Saskatoon Sk.
MF
Hi I'm a new member looking for advise. Looking at a GC1705L with front snowblower, RC mower, belly mower and tiller. Also at a the 1526 with the same options is there some way I can make a easy decision?
/ Confused #2
Welcome! You will get some great information if you describe what tasks you want to tackle, the terrain (flat, hilly) and how much land you will be maintaining.
/ Confused
I guess most of the work would be hauling fire wood with the loader and cutting small under brush with a Rough cut then haul dirt in seed grass.
/ Confused #4
If it make any difference to you, the 1526 is a discontinued model. MF replaced the 1500 series with the 1700E series. The difference between a 1526 and a 1726E is really weight. The newer model being significantly heavier, ~700 or 800 lbs. If you mow a residential yard, the 1526 would be the better choice.
Otherwise, the GC1705 will be the better mower, its smaller, lighter, more maneuverable, etc. The 1526 will be stronger and have more capacity, and be better for tractor duties. I have a GC2400, predecessor to the GC1705, and I kinda wish I had a 1526!
/ Confused
I have found a used 1526HL with 100hrs. It has a rear 3pt blower. It's a 2012. The price is about the same as a new gc1705 with a front snowblower. AGCO also has a few new ones around as well.
/ Confused #6
Conversation I had with dealer is 1526 is being reintroduced because of mid mount pto.
That was in July
/ Confused #7
That was in July
Thats the second time someone has said that...so maybe there is some truth there...
/ Confused #8
Unless you need the extra capacity/strength of the 1526, then I would go with the GC1705 and front blower, especially if you get a decent amount of snow in your area.
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
YANMAR VIO55-6A EXCAVATOR (A63276)
YANMAR VIO55-6A...
2014 Chevrolet Caprice Sedan (A61569)
2014 Chevrolet...
SET OF 26' & 36' GATES (A62131)
SET OF 26' & 36'...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
UNUSED SDLANCH 20' X 30' ALL-STEEL CARPORT (A62131)
UNUSED SDLANCH 20'...
