Do liquid fill tire expand?
   / Do liquid fill tire expand? #11
Maybe youre trying to put the pins in with the arms at a different height than you did before. Usually more room when the arms are down.
The the hitch has to be at it's highest (or nearly so) to have the holes on the backhoe match the holes on the tractor frame.
Having said that, when the Rim Guard was pumped into the tractor's rear tires the stem had to be at the 12:00 position. Rather than me drive forward or back a few feet, the installer used a jack to lift each side of the tractor till the wheel on that side was off the ground and then he rotated the tire into the 12:00 position. After filling the left tire he put it down and then did the same to the right tire. Today while I was trying to figure this out (reducing pressure to 20 psi didn't help, they were already at 22psi) I noticed that the rear tires now have a noticeable toe in (out?) difference. The bottom of each rear tire appears to be further out from the tractor than the top. That is, the tires appear canted so that they appear to lean into the tractor. The manual discusses measuring and adjusting toe in on the front tires but nothing about adjusting a cant on the rear tires. Could lifting the tires and adding weight (about 550 lbs/tire) affect the tires in this way. I believe if the tires were vertical (as opposed to canted) I'd have the necessary room to install the pins. Any suggestions?
   / Do liquid fill tire expand? #13
it could also be sagging... you can add pressure to fix that
   / Do liquid fill tire expand? #14
Sorry that lowering the psi, didn't help, but would not expect that it would if it was only at 22psi. I have seen all to often where the rear tires were at 30-35psi and then that would have made a difference. Have you driven the tractor around much since the tires were filled? Just wondering.
   / Do liquid fill tire expand? #15
You are supposed to jack up rear and take weight off to fill with liquid.
If you are thinking the rim or axles bent all you need to do is drive it around and if it bucks you out of the seat - they are bent. If it doesn't, it's your eyes playing tricks.
   / Do liquid fill tire expand? #16
Also, can you take some pictures of what you got going on here? Something will jump out and this mystery can be solved I am sure.
ill try to get pics tomorrow. Right now the rain has me thinking about plans for building an ark.
I've probably put 12-15 hrs on it since the tires were filled. It's not "bucking" me off off so don't believe that there is an issue with the axle.
   / Do liquid fill tire expand? #18
If you hear a voice that says do so I would be gathering some gopher wood and get to building if I were you.
   / Do liquid fill tire expand? #19
The bottom of each rear tire appears to be further out from the tractor than the top. That is, the tires appear canted so that they appear to lean into the tractor. -------------
Jack up one side at the rear enough to get the tire off of the ground and see if the angle changes.
Be sure to block the other wheel so the tractor can't move.
   / Do liquid fill tire expand? #20
Are you rear wheels loose or something? They should not be able to tilt like that unless something got bent (in which case taking it for a drive will let you know in a hurry)
2006 CHEVROLET EXPRESS SERVICE VAN (A58017)
2006 CHEVROLET...
John Deere 4600 (A53317)
John Deere 4600...
2014 BMW X1 AWD SUV (A56859)
2014 BMW X1 AWD...
2004 VE ENTERPRISES 500BBL FRAC TANK (A58214)
2004 VE...
2016 FREIGHTLINER CASCADIA (A58214)
2016 FREIGHTLINER...
2007 Volvo VNL Truck Tractor (A56435)
2007 Volvo VNL...
