1025R backhoe specs?
/ 1025R backhoe specs? #1
rider7767
Paris, TN
TYM T264 with loader and implements
I am in the process of buying a new JD1025R with loader, mower and backhoe. Does anyone have the specs on the backhoe? I believe it is a 260 backhoe. I sign the papers next week, and I forgot to ask the dealer. They will not be in until next week. Every other tractor manufacture post the specs on their website.
/ 1025R backhoe specs? #4
Hi I know this thread is a little old but I'm the proud owner of a new 260 hoe I just installed on my 2305. I find that John Deere's specs and real world are often different (example my 200cx will pick up way more than the 600 odd pounds it's rated to). I do recall seeing roughly 2000 lb break out force and 350ish boom lift. 6'2" digging depth. I do have a burning question for those op or any 1023/25 guys. In the specs John Deere says "180 deg swing arc on most models" I know there are 2 variations (different s.n.) for the 2305 and the 1025. What I want to know is if the newer tractors actually swing 180 side to side? Mine is only 150 and there are times I wish it was more. Other than that I'm blown away by what I can do with it. I wanted one for 5 years since buying my 2305 and was not disappointed!
/ 1025R backhoe specs? #5
Also if anyone is interested... I quickly became paranoid about grit getting on the stabilizer cylinders. I saw JD offers a protection kit but it seemed pricey for what it was (130$) so I picked up some vinyl like fabric and made my own! 9$ and an hour of my time to hand sew them. View attachment 447604[/ATTACH]
/ 1025R backhoe specs? #6
I would think the cylinder protectors are to protect them from large rocks striking the cylinders. The ones on my 110 are formed steel plate. Grit I would not worry about.
/ 1025R backhoe specs? #7
Steel plate was a thought but for the 260 the JD protection kit is just a heavy fabric wrap. I believe that the dirt/rocks whatever they come in contact with will scratch the chrome plating and take out the seals over time. There is a product called seal saver that is just for that purpose to keep the crap off the cylinders so it doesn't start causing issues. I think my fabric would at least stop a rock from scratching it and it would take doing something really dumb to damage them.
/ 1025R backhoe specs? #8
Not that this is a huge issue I'm sure there are a lot of 260s with a lot of hours and no issues I was just being overly cautious with my new toy but didn't want to shell out 130$ for something that simple.
My backhoe will absolutely not do 180 degrees. Maybe 150-160 degrees. That is not that big of a deal to me.
2018 INTERNATIONAL LT625 (A67714)
2018 INTERNATIONAL...
2019 INTERNATIONAL MV607 REEFER TRUCK (A67714)
2019 INTERNATIONAL...
2014 MAGNUM FRAC MANIFOLD TRAILER (A67714)
2014 MAGNUM FRAC...
2007 KENWORTH W900 (A67714)
2007 KENWORTH W900...
2014 Crane Carrier Co. Low Entry T/A Rear Loader Garbage Truck (A66736)
2014 Crane Carrier...
PORTA POTTY (A68842)
