M59 Rear Hydraulic Remotes Question
/ M59 Rear Hydraulic Remotes Question #11
I know next to nothing about the M59. Is there no "Power Beyond" port? Or how does the backhoe get its hydraulics?
/ M59 Rear Hydraulic Remotes Question #12
There are a couple of places where "power beyond" is available. The backhoe uses one and that would be the answer.... but that's already in use with the backhoe connected - as it usually is.
I believe that when mike ordered the rear remote option that it uses a a factory plumbed connection to the rear distribution block to run the rear remotes. It sounds to me like mike is looking for an additional full flow power out port from his rear remotes valves. I don't have the rear remotes on mine....so I don't know all the details on that system. So I listed some options. None of those I mentioned are strictly Kubota OEM - but they will all work.
Kubota might have yet another way of doing it with factory parts. But if so I don't know it and don't see it in the manual.
luck, rScotty
/ M59 Rear Hydraulic Remotes Question #13
luck, rScotty
Ok, got it. I was imagining the hydraulic motor (or whatever the OP wants to run) on the 3 point, which would have made the PB available.
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
2014 Ford F-350 Pickup Truck (A55973)
2014 Ford F-350...
Giyi LS43 QA Log Splitter (A60463)
Giyi LS43 QA Log...
Bush Hog 2212 (A60462)
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
