Comparison Tym vs Branson vs ?
/ Tym vs Branson vs ? #1
jrbarnard
Cedar Creek, TX
None
Hi guys, have not posted in a while.
We have been busy.. heh.. bought 2 acres and are planning to build a house. Now, we also own 330 acres of hunting land. Here is what I am curious about:
1 - I really do not need a high end tractor. Let's be honest, so long as I do not say this to my wife.. lol..., I WANT a high end.. but I can get by with a smaller one.
2 - I need to be able to mow, but getting just a mower, to me, would be a waste. I have seen Kubotas that look like riding mowers but with buckets on them and a friend even has one and he states it is almost too small for his place (same size place).
So, I am trying to justify and also pick something that is more useful and I have seen a lot of interesting package deals with Branson as well as TYM. The prices are close, but here is what I was looking at possibly getting, and then why I was curious:
I need a brush hog and a bucket. I would LIKE a backhoe, but that is all based on price per month (financed). a Box blade on the back would be nice.
Many of the Branson packages I see come with augers, box blades, brush hogs, trailers, etc..
I was interested in the Branson 2400... but I heard TYM makes a good tractor also, but did not see any packages with all the same implements and the price is like 2k more for the same "hp" models.
Is there a good difference between the two? Cheap is not my goal, but a good deal is.
Are there other makes you might suggest in the same price range?
I know I will not be able to do near as much with the lower models, but if I can do food plots at the deer stands and roads etc, and cut the grass at my house...I am better off than naught.
And no, not looking at this year. I have to get the house built first THEN the workshop to store it in.. heh
Thanks guys!
Russ
/ Tym vs Branson vs ? #2
I own a Branson 3510I. I own 20 acres. I do a lot of Forestry work and Farm construction and maintenance (moving Dirt. rocks. stumps and tree trunks and brush equipment and digging trenches and various holes. I have a back-hoe with a thumb, a loader, box blade Hydraulic-grapple, pallet forks and drum lifter and post-hole digger. I do not mow grass with it. I wish I had bought the Hydro-static version however. The clutch is strong and will most likely irritate your nee just like it does mine after several hours of use. Other than that, the Branson is a tough, strong, heavy duty beast. It out performs all the tractors (Kubota. Deere. TYM, Mahindra...) in its class around my East-Texas Forestry friends. Only problem I have run into is the Dealer Network is getting slim for Branson. I recommend the Branson for my actual experience for price and performance weight, hydraulics and power over any other Tractor in its class. I have been around other tractors at the same time doing the same things. My Brother and cousins that borrow it all the time, say the same thing as I. Having said that I really like the tractor. I have had no problems with it but it is getting old now and , because of the Dealer problem I think if I replace it I would spend more money on a larger New-Holland, Bob-Cat, Case IH, or something like that. For your 2 acres you would be a very happy man with a Branson.
/ Tym vs Branson vs ? #3
The two Korean tractor brands with expanding market share in the U.S.A. are Kioti and LS. Kioti and LS make all their own stuff. Branson and TYM are South/Central regional brands plus a few in California. If you are a pioneer type person willing to accept above average parts and resale risk, in exchange for a lower price, Branson and TYM are fine.
In terms of sizing a new tractor for two acres:
Almost all 16-hp to 35-hp tractors sold in the USA are equipped with a FEL (Loader), HST transmission, 4-WD and Industrial (R4) tires; all "options" even though pretty much standard packages that will be on tractors you look at.
Tractors sold with 25-hp or smaller engines (in the USA) have relatively simple emissions controls referred to as Tier III emission controls.
Tractors sold with >25-hp engines require more complex, more costly EPA mandated emissions controls referred to as Tier IV emission controls. This is ALL brands of tractors. Tier IV is "new" in the last two years.
I think you will be fine with a 25-hp tractor. If you want something with more horsepower you may as well go to 35-hp because the factory addition Tier IV emission controls is costly, and not value efficient until you get to 35-hp. I believe new tractor sales in the 26-hp to 30-hp segment are thin at present.
All Kubota sub-compact BX models are <25-hp, so are Tier III
Slightly larger Kubota 'B' models fall on both side of the 25-hp divide.
One larger, heavier Kubota model, the L2501, a compact, rather than subcompact model, has a 25-hp engine and, therefore, is Tier III.
I recommend a Kubota B2320 (Tier III) or a Kubota L2501 (Tier III)
Kubota BX tractors are great lawn/turf mowing machines. Normally they use a Mid-Mount Mower (MMM) which is under the body of the tractor and comes in 54" and 60" widths. Great mowers but a little small for other tasks.
Some tractor owners prefer to mow turf with a 3-Point Hitch mounted Finish Mower towed behind the tractor. This would be my choice.
Kubota B2320 is a tad larger than a BX, which makes it easier to mount implements on the Three Point Hitch. A B2320 is about the same weight as similarly equipped BX.
L2501 is larger yet, and about 1,200 pounds heavier than the B2320. I think you need a Kubota L2501.
For dealing with shrubs, small trees and light grading, I recommend a $330 Ratchet Rake bucket attachment. These are sold by the T-B-N store, which has more information. Delivery by convenient FedEx. (STORE button at top of this page.)
Ratchet Rake on YOUTUBE: https://www.youtube.com/results?search_query=RATCHET+RAKE
Kubota L2501 Web Page: Compact Tractors | L2501 | Kubota Tractor Corporation
I have to get the house built first THEN the workshop to store the tractor in.
Tractors have neither VINs nor titles. Tractors are prime targets for thieves. Build your tractor storage first or bring in a CONNEX container to lock up your tractor within, then build your house. Otherwise your new tractor may go to Mexico in short order. Stolen tractors are very, very, seldom recovered.
I have owned one John Deere tractor and two Kubota tractors, never a Korean tractor. I have shopped the Kioti and LS brands and been favorably impressed.
/ Tym vs Branson vs ? #4
Check with your Mahindra dealer. The Max series is just what you're looking for. It has a lot of sales and a real good reputation. Well made, dependable machines.
/ Tym vs Branson vs ? #6
We own 330 acres of hunting land.
There are many ways to prepare food plots, like any other ground contact enterprise.
The most common implements used, and the way I do it, are a Disc Harrow to chop up sod prior to seeding and use of a Cultipacker to press in seed and reduce probability of erosion.
The minimum size of Disc Harrow which is effective has 18" diameter pans, spaced 9" apart. A heavier Disc Harrow with 20" diameter pans, spaced 9" apart is better. You cannot pull 18" nor 20" pan diameter Disc Harrow with a 25-hp tractor. You need a 35-hp (+) tractor with ample weight.
Cultipackers, which ride on top of the ground, do not require a powerful/heavy tractor unless hill work is involved.
There are a number of clover based NO TILL food plot seed mixes available. The forage only comes up 4" to 5" so yields are much less than other seed mixes which commonly grow up 36". With 330 acres NO TILL seed mixes may be your ticket.
All great input, tyvm. Sorry to respond slow, I had a busy day yesterday.
Question for you all. What is the smallest tractor you can get that has a cab? I keep getting told that having a cab will protect me from bees if I am working at the ranch (they get pretty bad out there) as well as allow me to use it in all sorts of weather (usually 100-ish most times of the year) and it is only like 4k more for a cab... albeit I think TYM has a 354hst that is the smallest a cab will go on, but there was not a huge difference in price.
I know talking about a Branson 2400 vs a T354 HST just ratcheted up the price like.. what, 8k? (which I do not think I would want to do... but since I would finance it.. is that really a huge 'per month' cost that, if I can afford.. might be worth the expense to get more work per month out of it?
Just trying to factor and think about all options here.
And, again, thanks for all the great input.
Jeff - Great info there. I will make sure to look at all of those options and check out the Kubota place down the road from my new house. TYVM.
Russ
/ Tym vs Branson vs ? #8
What dealers are close to where you live? How long have them been dealers? I've noticed that with some brands, the dealers pop up and disappear almost yearly. While I think all the brands listed are fine and good bargains for your money, I would go with the dealer who has been there long term. There isn't any real difference between any of the different brands out there. People are going to recommend what they bought because they are proud of their tractor without any experience or first hand knowledge of any other brand. Others will bad mouth a particular brand because the dealer they bought it from didn't do what they wanted, or should have done. Every brand will have a few problems regardless of what you paid for it. A good dealer with a good support infrastructure from that brand is the most important thing to consider.
/ Tym vs Branson vs ? #9
Are you looking at Mid mount mowers or 3 PH rear finish mowers. On the Branson 2400 & 2800 the Mid mount really reduces your ground clearance.
Like Eddie says: Dealers are just as importatnt as the brand. All brands make good & bad, tractors depending on your requirements and perspective.
/ Tym vs Branson vs ? #10
I think it might be a good idea to at least check out a more established brand that is used but low hours. You could get some nice upgrades, cab, Hst,maybe an implement thrown in for a lot less money than new. My neighbor just bought a sweet Kubota L 3200 with 155 hours on it, looks like a brand new unit to me. He is a thrifty guy and waited for a good deal to come along. Sound like you're not in a big hurry, so enjoy the hunt.
/ Tym vs Branson vs ? #11
................. What is the smallest tractor you can get that has a cab? I keep getting told that having a cab will protect me from bees if I am working at the ranch (they get pretty bad out there) as well as allow me to use it in all sorts of weather ......................Russ
I'm not well versed on all the offerings of the different manufacturers. I can tell you that I test drove a smaller Kubota (B3030 I think) with a cab with air. It felt a little small inside. I looked at a bunch of different tractors when I bought this last one. One or two that offered cabs didn't have A/C available, which may make them unacceptable for your area. The one place I shopped had Mahindra and TYM, and the smaller cabbed tractor of one of those brands lacked A/C. There's another off-brand red tractor dealer that came and went near here and I can't recall the brand. Pretty sure they were also heat only.
/ Tym vs Branson vs ? #12
A good tractor can easily work hard for 40 or 50 years. Do not go cheap just to save a few bucks and not be satisfied with your purchase or have it break down after a few years. Our Massey 35 was purchased in 1961 or 1962 and was still working fine when I sold it a few years ago (Sold most of the farm, so didn't use it much). If you are not a good mechanic, a good dealer is especially important. A backhoe is nice, but one can be rented cheaper if it is not going to be used weekly or monthly in most cases. I am sure you will be using it on both properties. Not sure if you will have to trailer it or not. Since you have time, see or talk to neighbors about what the have and how their dealer treats them. Good luck.
/ Tym vs Branson vs ? #13
I don't have the exacts in front of me....but I can get them if necessary, but you did not give Branson credit where credit is due! Your facts are not factual!
Mark
/ Tym vs Branson vs ? #14
Every tractor I've had, old and new have VINS. They might be called serial numbers but they're the same. It's the only real way you can tell what year they are made.
/ Tym vs Branson vs ? #15
VINS are in a federal data base which can be easily accessed by law enforcement and DMV. Each time a vehicle is titled, the VIN is checked to be sure current seller matches last registered owner.
Serial numbers are not.
/ Tym vs Branson vs ? #16
Not to pick nits here but.....you may not be able to trace a number thru the police, but your dealer will have a record and so should the owner. The number which is on the machine is traceable to an extent. It is a vehicle identifier. It helps identify the machine for repairs, manuf date, and ownership.
It is on a Vehicle
It is an Identifier
It is a Number
VIN
They all have one.
/ Tym vs Branson vs ? #17
I believe the smallest factory cab tractor is the Kubota B series. The 2650 is Tier 3.
/ Tym vs Branson vs ? #18
Russ
Greetings Russ,
I've read your posts on this thread plus many responses to it . . . and there is a remarkable quantity of errors or omissions in data needed.
Lets start with your posts. To get good opinions . . you need to clarify information. Having product "packages" for a car/truck is much different than for a tractor. On a car or truck a package is a combination of things that is built and installed together. But what you are refering to is a tractor and a bunch of addon implements. So a tractor and front end loader, 3 pt hitch and backhoe may be a package but an auger or bush hog or ??? are simply implements thrown into the quote. Keep it simple . . . by identifying the tractor characteristics you desire first.
Next . . . in your search for brands and sizes . . I recommend NOT to consider distance to dealer as a priority. Dealers go out of business, switch brands or sell out all the time. If a dealer is 100 miles away or 3 miles away . . focus on finding GOOD dealers not close ones . . and backup ones too. Distance is somethong you can deal with . . quality and reliability is not.
Next . . if you post an open sizing option . . . you don't do yourself any favors because to tractor owners they see "size" in very different viewpoints . . and you get flooded with huge size difference opinions. As an example . . 2 acres of grass and 330 acres of hunting land are huge gaps depending on terrain variables and types of of plans you have.
Next . . help readers by targetting your questions if you can. Will your lawn be flat or hills and slopes. Will you have any tricky washes or rock outcroppings or culvert issues? Will your driveway be gravel or concrete or blacktop. Will you have snow issues or not. All these things determine size of tractor benefits. How about ground clearance needs . . 2 acres of lawn isn't an issue but 330 acres of hunting land to many readers indicates size variances of tractor.
My point is . . . you desire input which is good . . But 100 responses with 6 sizes of tractors is not helping you even though readers are trying.
Continued
/ Tym vs Branson vs ? #19
Greetings Russ,
Now to the other side of the story. Your getting some errors, omissions, or incorrect information and you need to recognize or know them as errors.
1. You mention TYM tractors and some responded. Yet neither you or them mentioned that Cabelas chain also sells TYM tractors under their own name and also does the service and warranty work work on the Cabels/TYM tractors. In other words TYM product has expanded because Cabelas is a growing national chain. Also Cabelas offers some 4 or 5 sizes (frame sizes). And if parts are needed . . not only do they do local full service and warranty work at each location . . but they can also ship parts thru their warehouse sustems.
2. I'm stunned by some info you got on Tier IV engines. A Kubota bx2670 is a 26 hp scut yet it is a tier lll engine. Thats because the engine has not changed since the rules went into 2015. But all diesel tractor engines will become tier iv engines. In fact right now some of the best known tractor brands are tier iv engines in the 25.999 hp and smaller . . Yanmar, Massey, Mahindra etc... And in larger engines . . Yes . . Tier iv makes some difference in maintenance costs . . But the 25.9999 hp and below is just engineered a little better and cleans the diesel exhaust a little better. No performance loss or "canister" or egr vslves needed.
3. Cabs. On my Massey GC1715 I can add a cab . . Either fiberglass or cloth from numerous manufacturing vendors . . Virtually every modern tractor has that option thru vendors and the cheaper ones start at less than 1,000. This is in addition to brand manufacturer options which are often 3rd arty anyway.
4. Air conditioning. Well maybe you don't need it if you have "forward engine cooling". I don't know about the compact tractors but in just sub compact tractors some of the best and biggest names have the radiator and cooling fan at the back of the engine instead of the front . . so hot air goes out the front not on the driver . . plus it keeps the engine comparyment (and driver) much cleaner too. Kubota bx models all have it. Yanmar sc2400s have it, massey gc2300 gc2400 gc1700s all have it and maybe other brands and sizes too . . this isn't a complete list.
5. You are building a house. I was too over several years. I wish I had bought my tractor then because there were many things I could have used it for that I either had to rent or have someone do it for me or wheelborrow or cart or trailer.
6. No one suggested you do more homework. Everyone who responds is already an owner so they are iffeing opinions. Nobody reminded you that just in kubota bx there are 4 models and then in small b models there are 2 or 3 more . . when you referred to a kubota as a lawnmower with options but it seemed a bit small. Did you see a bx1870-1 or a bx2670-1 or a b2601 or ??? Point is they should have stopped you from making an assumption on a sighting of one unknown model.
7. Food plots. A rear cultivator can be used with most all scut and cut units. Unless you have hardpan surfaces or try to develop plots in heavy root or rock areas . . Any size can do it depending on ground clearance. Also you can rent implements too.
Russ . . I'm not a know-it-all. I've been thru much of what you are doing. I spent years clarifying because I COULD NOT AFFORD to make a mistake. I recognized that in our area a good scut used was almost the same as a new one . . and my terrain demanded i have great traction on grass lawn slopes and hills and snowy situations. Many of these readers routinely buy another tractor because they can afford to or becsuse they owned tractors for decades. I had to get it right the 1st time because stretching out payments further and further to get whatever was not my desire. And cost WAS an issue I readily and frequently admitted.
If you buy new . . virtually every brand has great financing options. Used units are easily financed at credit unions etc. With great rates. Go see dealers and look and test drive. I contacted more than a dozen dealers before I found one I liked (dealer). In addition I found a couple other really good dealers with different brands I really liked. There were HUGE differences in dealer/sales knowledge of their product.
My point in all this is simple. . . new or used . . listen to all input . . but seek knowledge and double check everything unless you have lots of money. A tractor is a great thing but none of them do all your wishes . . hire some things done . . and do some yourself.
Good luck and work hard on it . . . you'll be glad you did . . and so will the wife.
/ Tym vs Branson vs ? #20
You are correct for many reasons. Every tractor has a unique number. Its how invoicing is done. Its how warranties re recognized. Its how recalls are handled. Inthe U.S. it is required and to my knowledge every implement has one too . . . My fel . . My mower deck . . My 3pt sprayer . . . My tractor. My insurance coverage is based on those numbers too as is my financing.
2014 International WorkStar 7500 T/A Leach 2RIII 25Yd Rear Loader Garbage Truck (A66736)
2014 International...
Polaris Ranger 4x4 Gas Utility Cart (A66734)
Polaris Ranger 4x4...
2005 DYNAPAC CA152PD PADFOOT ROLLER (A67714)
2005 DYNAPAC...
2012 FREIGHTLINER M2112 S/A GARBAGE TRUCK (A66091)
2012 FREIGHTLINER...
ALLMAND MAXI-LITE II V-SERIES (INOPERABLE) (A68842)
ALLMAND MAXI-LITE...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
