Loader fitting to John Deere 6120
/ Loader fitting to John Deere 6120 #1
meyersd
high range,NSW
JOHN DEERE 6120
I am buying a Quickie loader to fit to a 6120 purchased recently.
Want to keep the remotes available, so need to know where to connect the hydraulics at back of tractor.
Have read threads about power beyond port & know I need to find out the configuration of my tractors hydraulics first.
The 3rd attached photo shows where I guess these connections should be.
Shows 2 of 3/4inch plugs, has a plug underneath also. Note the block with these plugs has a hose outlet teed to the 3PL rams
Any info on this would be appreciated
DAVID
/ Loader fitting to John Deere 6120 #2
You need a different right side end cover that replaces the current cover which is held on with three nuts. You will also need new longer studs. The cover will have four hose connections. Key #20, top is pressure to loader valve, bottom is return from loader valve. Key #11 bottom is LS (load sense) from loader valve and upper forward is LS to hydraulic pump.
Your loader valve must be LS compatible.
Thanks for that
Is the part in the picture a JD part
Asked the dealer what's required & he said use a power beyond port with 3 ports only; supply, return & load sense.
He did not mention load sense back to pump, could this be done via the connection to rest of block?
The dealer wants $1100 for the JD power beyond. Does this seem right or can I get an aftermarket unit ?
/ Loader fitting to John Deere 6120 #4
Here's one power beyond for a 6120
AR113482 Hyd. Quick-Connect Coupler - FIELD INSTALLATION KIT, POWER BEYON ADD 220.13 USD 220.13 USD
AL163533 Cover - COVER, END COVER ASSY, LH ADD 386.99 USD 386.99 USD
*total 607.12 USD
/ Loader fitting to John Deere 6120 #5
Thanks for that
Picture is all John Deere parts.
Dealer might have only been thinking what goes to the loader valve, supply, return and load sense.
Key #12 is part number AL117097 list is $290.24
Key #24 is part number AL158831 list is $314.60 Gives all parts shown in box 24 of drawing.
/ Loader fitting to John Deere 6120 #6
Dealer may be thinking of this spacer key #43 in the drawing, part number AL166506 list $152.23. It does not have a load sense going to the pump. I am thinking this spacer is used when you have the 3rd SCV.
/ Loader fitting to John Deere 6120 #7
*total 607.12 USD
Jim,
AL163533 is key #1 in your drawing, it appears to be included in Ar113482, key #32 in the drawing. Hard to believe you can buy everything for less when you buy the complete FI kit.
/ Loader fitting to John Deere 6120 #8
I think the cover isn't included in the PBY BUT one would have to contact dealer to determine but according to JDparts.com kit weighs nearly 12#s..
/ Loader fitting to John Deere 6120 #9
Service department should be able to print out install instructions. That should have a parts list.
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F-250...
2010 48 ROLL OFF TRAILER (A65643)
2010 48 ROLL OFF...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
2013 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2013 Caterpillar...
