whats in your tool box
/ whats in your tool box #1
cvcman
syracuse ny
john deere
my xj2025h doesn't have too big a tool box but...it holds a ball pien hammer,utility knife,roll of blk tape, needle nose plier, slip joint plier, reg screwdriver,phillips screwdriver,dia cutting plier, two adjustable wrenches,rag, wire, few zip ties, few bandaids
/ whats in your tool box #3
I have most of the same tools you have in mine plus extra lynch pins. Now my big 55 hp diesel tractor I have a regular size tool box bolted to the fender. You can kinda see it in my Avatar pic. That box has everything you listed plus two 9 piece wrench sets metric and standard. A few pipe wrenches, hitch balls and more..
/ whats in your tool box #4
My inclusion would be one or two spanners (crescent wrench) in a typical diameter. 17mm is one of the sizes & it's not usually included in a 'set'.
/ whats in your tool box #5
I thought you said it had a small tool box!!!
My small tool box that I put on both tractors (neither came with a tool box) contains only basic needs. Extra snap ring pins for lift arms, channel lock pliers, a pair of gloves and room for a couple bottle of water. If something cant be fixed with channel locks, it goes to the shop for repair. I did keep a hammer and pipe wrench in my LS to use to tighten the axle nut on my disk but no longer use it since I got my tiller so those went back to my shop storage.
/ whats in your tool box #6
I have extra snap ring pins, set of big channel lock pliers, roll of toilet paper, energy bars and a big bottle of water.
its pretty small
/ whats in your tool box #8
Oh yeah, forgot to mention to include a few (package?) of medium sized tie-wraps (zip-ties?) in there. Very little space taken up & they're as handy as all get out.
/ whats in your tool box #9
cvcman have had any issues bending your key from hitting it with you knee? Seems to be an issue with me when getting on and off lol.
/ whats in your tool box #10
Good point. Medium and large size. Love cable ties!
2016 Ford F-650 18ft Rollback Truck (A61568)
2016 Ford F-650...
iDrive TDS-2010H...
John Deere 5420 Tractor with Quicke Loader (A64047)
John Deere 5420...
2014 Kubota KX057-4 Mini Excavator (A61166)
2014 Kubota...
Kubota B21 TLB (A60462)
Kubota B21 TLB...
1999 DYNAPAC CA252D SMOOTH DRUM ROLLER (A62129)
1999 DYNAPAC...
