JD 2550 pump question
/ JD 2550 pump question #21
One needs to test each hyd component for pressure,flow(GPM) & temperature. Many closed center hyd pumps have been replaced to learn that frt pump was fine and some other hyd component was at fault. One simple test is look in hyd filler hole for spraying oil with 3 pt raised while engine is running.
/ JD 2550 pump question #22
As above have stated, you need a flow/load meter test......everything else will just be guessing
Pumps that pump so/so when cold or at high revs but get worse when it warms or idle is classic symptom of pump worn out.....rule out the pump first
/ JD 2550 pump question #23
I disagree since frt pump can't suck oil it is very dependent on oil being supplied from trans pump. Also major internal high pressure leak will rob a good pump of it's output. One needs to eliminate internal leaks,check trans pump flow before condemning frt pump. Many JD frt pumps have been replaced with new pumps to determine that pump wasn't the problem. Closed center hyd's problems can be a PITA to diagnose.
/ JD 2550 pump question #24
All gear pumps can suck oil from a tank.
However if the supply is too low or is reduced such as a transmission fed pump, then it will make lots of noise and eventually wear out if not corrected.
You can also remove the pump for a flow and pressure test.
On a closed center system, you can check the out/tank line for flow when there should be none with all valves in neutral.
/ JD 2550 pump question #25
JD frt pump on closed center system is a piston pump. Removing JD frt pump is a job that one will not want to accomplish very often.
Are you saying to check each valve for flow separately, or check the main pump? I was thinking there would always be flow from the main pump since components such as steering and trans pump use the same fluid.
So my next step is to check the trans pump and main pump for flow/pressure? I apologize if this is a dumb question, but is there a way to supply fluid to the front pump externally to guarantee its getting fluid?
/ JD 2550 pump question #27
To check each valve for leakage, remove the OUT hose.
I an not sure if the closed center pump uses a separate return line for excess flow or returns the flow back to the IN port of the pump. .
/ JD 2550 pump question #28
I think power steering valve has no return hose to check flow. Actually frt pump isn't designed to have excess flow because when stand-by pressure is attained hyd pump stops pumping oil.
/ JD 2550 pump question #29
Oops, my bad........was thinking it was a positive displ open center pump:ashamed:
/ JD 2550 pump question #30
Hey Guys
I am here searching because I am in the same boat as MMagis was. I hope he found and fixed his problem. I am in North Carolina this weekend and after two days of hard work my 1985 JD 2550 loader and three point quite working. Friday I did have a chattering in the hydraulics a few time but it quit and things worked properly when it went away. Yesterday it was working great and I got off and back on and now I can barely get the buck or the three point up. By barely i mean a my not be able to load the tractor up on the trailer. The steering works normal and I was told that comes from the internal pump, is that correct?. I do not have my pressure gauge or many tools, as they’re back in Georgia so i am handicapped at this point. Please give me your thoughts and opinion. I will check what I can before taking it somewhere. I will try to raise the three point after church and see if I can see any oil leaking internally. Thank you in advance
Blue Diamond 103709 (A53317)
Blue Diamond...
SCAN TO RECEIVE TEXT UPDATES (A62130)
SCAN TO RECEIVE...
(INOP) 1998 FORD F-SERIES FLAT BED TRUCK (A59823)
(INOP) 1998 FORD...
XCMG CV83PD (A53317)
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
2023 John Deere XUV 825M S4 (A60462)
2023 John Deere...
