Suspension seat upgrade
/ Suspension seat upgrade #1
SwampmanLA
After an extended bit of downtime on my 422 I spent last Saturday digging, pushing, and moving all sort of stuff that had been needing to be taken care of during said downtime. Well the beating my back took sent me to the doctor this week for relief from sciatica. Doc says I ain't as young as I once was, no kidding. My question for the group is .... Has anyone successfully installed a suspension seat on a 4xx machine? What tips might you have in doing so?
/ Suspension seat upgrade #2
I recall a suspension seat on a 400 series and I recall someone putting a seat on some sort of hanging thing and maybe some small springs. I think the problems people are having is the suspension bounces your skull into the steel canopy. Maybe there was a low profile suspension seat. You'd have to spend some time with the search engine to find the posts about it.
/ Suspension seat upgrade #4
Very nice setup..
/ Suspension seat upgrade #5
Ken has the real mans version, I have the poor mans version.
I put in rubber grommets or springs on the screw shafts of the seat between the seat and the plate that holds it. They really help and don't raise as much as Kens setup, but I still drool over kens setup.
/ Suspension seat upgrade #6
Yes he did a nice job.
I guess everyone has their priorities .. If I used mine for mowing grass bouncing around in the seat for hours at time. I know I would have looked into a suspension saddle. For the limited amount of time I've used my PT's I've never found them to be uncomfortable..
I'm sure rubber grommets / springs work great at improving the ride.. But It's never too late to go back and try his setup..
/ Suspension seat upgrade #7
Don't have a PowerTrac, but hated the cheap seat on my tractor, replaced it with a low profile suspension seat, cost about $160. Huge difference, life is better now, no flinching on rough terrain anymore, noticeably less fatigue after a long day. Seat is about 2 inches higher than before, but you get used to that pretty soon.
/ Suspension seat upgrade #8
Any links to that seat? Low profile is what PT owners are looking for as many of us have steel canopies over our heads.... BUMP! OUCH!!! :laughing:
/ Suspension seat upgrade #9
I just installed a new suspension seat on my eXmark, I have wanted one since I bought it in 2001 and it makes all the difference in the world!
/ Suspension seat upgrade #11
I would definitely try Woodland Farm's setup before spending the money I did. I was not smart enough to think that would work. I also never take advantage of the slide mechanism either. It is set all the way back, I believe.
/ Suspension seat upgrade #12
JJ, All of those seats look comfortable but they also look like they are thicker than my whole setup - not sure we have that kind of height with the FOPS. Without the slide rails, my setup would add about 2 - 3" to the height of the seat vs the powertrac seat.
Ken
/ Suspension seat upgrade #13
I padded the underside of the ROPS. IT helps a little with noise too.
/ Suspension seat upgrade #14
I think I've found a solution. All you need is a torch or plasma cutter, a welder, and one of these....
Cut a hole in the canopy, weld it in and now you're suspension seat will work perfectly.
/ Suspension seat upgrade #15
You are a genius!!!! And the rounded profile does not snag on branches in the wood.
Version 1 - blends in with the barn:
Or for tractor parades or loader work out in the open:
/ Suspension seat upgrade #17
If you want to spend that kind of money then look at the suspension system on my page. It is a top rated extra low suspension system that works well. It adds about 2" after you sit in it. I even wear a cowboy style hat that is resting high because of hearing protectors and it does not hit the FOPS.
Ken
Pabreak 84in Hydraulic Serrated Dozer Blade Skid Steer Attachment (A61567)
Pabreak 84in...
208315 (A58376)
208315 (A58376)
2015 Chrysler Town & Country Van (A61569)
2015 Chrysler Town...
2006 International 7400 SFA Terex Hi-Ranger 6TC-65 65ft. Insulated Bucket Truck (A60352)
2006 International...
2025 SDLANCH SDLC2020 High End Carport (A60352)
2025 SDLANCH...
2018 Chevrolet Cruze Sedan (A61569)
2018 Chevrolet...
