Can these be extended?
/ Can these be extended? #1
jodebg
New Hartford, CT
Kubota B-2650
My questions are can they be extended to 36-42"
and will they be strong enough to use on the FEL
and 3 ph with a max lift capacity of 1700 lbs.
If so, any suggestions as to material to weld on to extend?
My questions are regarding the forks. The brackets
I will need to cut and reconfigure.
These were used on a Bolens tractor. They fit onto a plow and
were used to move materials.
The forks are 3" wide and the upright bracket is 1/2" thick.
/ Can these be extended? #3
Around here you can buy "condemmed" forks for a hundred bucks. Usually someone drilled a hole in them and that is a no-no. A hundred bucks doesn't go very far in material and labour to extend them.
/ Can these be extended? #4
Came by a set of forks for sale.<img src="http://www.tractorbynet.com/forums/files/customization/437699-can-these-extended-bolens-pallet-forks-jpg"/><img src="http://www.tractorbynet.com/forums/files/customization/437700-can-these-extended-underarm-jpg"/>
Bolens??? I never knew they made bigger then garden tractors
/ Can these be extended? #5
Can they be extended? Yes. Will they handle 1700 lbs? Absolutely not! The half inch plate that those C channels are welded to will bend with that kind of leverage on them.
/ Can these be extended? #6
That looks like some kind of cast product. I wouldn't trust it to pick up 1700# as is. I have never seen forks made from anything other than solid hardened steel.
Don't trust those things with any thing valuable till you load test them and don't let anyone or thing get underneath a load with those cast forks.
/ Can these be extended? #7
If you do extend them. You may want to put heavier channel over the top of the whole fork and then beyond. Weld it in that way. I wouldn't do it end to end that's for sure.
Thanks for the information.
I am not going to purchase these.
Thanks again.
/ Can these be extended? #9
I got lucky and found a pair that were just phased out in the middle of a yard full of nearly worthless junk that'd been bottom dragged well beyond the 10% limit for de-rating. Bottom paint was hardly scratched! $100 just the same. :)
/ Can these be extended? #10
Those forks look like cast iron. Their design looks to be poor all around. I would keep looking.
/ Can these be extended? #11
Came by a set of forks for sale.View attachment 437699View attachment 437700
My forks are slightly less than 4" wide. I used a length of 2x4 tubing for the extension. Slide into the existing forks and use one bolt. You can probably use a 3" tubing. If they are a little tight, grind.
/ Can these be extended? #12
Cool- looks like a home-made grapple system. I would be concerned about bending the bucket with much load on the ends of those forks, though. For brush, just the ticket.
2015 Texas Trailers FB3330B 33ft. 22 Ton T/A Tag Trailer (A64556)
2015 Texas...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
2021 BROWN & HUBERT 10' SPOOL TRAILER (A63276)
2021 BROWN &...
2015 Global M3 Street Sweeper (A64556)
2015 Global M3...
New/Unused Wolverine 84in Quick Attach Rock Bucket (A65583)
New/Unused...
1990 Chevrolet P6000 Command Center Step Van (A64556)
1990 Chevrolet...
