Buying Advice Do I NEED or WANT a tractor?
/ Do I NEED or WANT a tractor? #1
timrf79
North AL
none
We just bought a house (November 2014) on 13 acres in North Alabama.
The property is hill side (everything is sloped, partially steep).
Out of the area about 1-2 acres is grass, the remainder is forrest.
I have a 1992 riding lawnmower, and I think I want to upgrade to a tractor with a FEL and back hoe, as well as mowing deck.
4WD to avoid wheel spin.
Eventually I want to put a trail in the forrest, possibly make a pond or pool. Maybe even have a level grass surface.
What are your thoughts?
Do I NEED a tractor or is this the kid in me wanting a "Toy"
/ Do I NEED or WANT a tractor? #2
Welcome to TBN.................
Everyone needs a tractor and everyone wants a new toy so what's the problem.
I'd say something in the 30-40HP range would suit your needs but a 25-30HP unit would work well too. Figure what you'll think you need and buy the next size up.
/ Do I NEED or WANT a tractor? #3
As you live in Alabama, aren't your REQUIRED to have a tractor?
I used to live on the Gulf of Mexico. I have at least as much fun with my current tractor, my third, as I did with either of my boats.
General use tractors are not too good on slopes, especially for operators without experience.
I would consider a Ventrac, Steiner or Power Trac brand, all of which are engineered for slopes.
There is a specialty VENTRAC/STEINER forum and a specialty POWER TRAC forum here on tractorbynet.com. You need a certain mechanical aptitude to enjoy a Power Trac.
Most Newbies think they want an optional $7,000 backhoe. A significant number of backhoes sit in storage, unattached to the tractor, after the novelty wears off.
VENTRAC LINK: Ventrac Compact Tractors & Attachments
/ Do I NEED or WANT a tractor? #4
Heavliy wooded, steep, and pond - When I see those words those task are better done by a dozer hired for your place for about a week or two depending on the size of the pond.
After the dozer work then see if you need a tractor for maintenance or if your mower will work.
/ Do I NEED or WANT a tractor? #5
Every time I say this I get in trouble after all it is a tractor web site, but consider a skid loader, it is worth a look. Unless you are actually going to plow a field IMO a skid loader will do everything you described. You will have to keep your current lawn mower.
/ Do I NEED or WANT a tractor? #6
You question is worded wrong, the question is "Why don't I have a tractor already". Its all about perspective!!!
/ Do I NEED or WANT a tractor? #7
Mistake #1, coming to a place like this asking weather or not you NEED a tractor....duh....of course you do!
/ Do I NEED or WANT a tractor? #8
I don't understand the question. You live on 13 acres, with hills, in north AL. You need tractor-like stuff done.
What was the question again?
More than likely the answer involves something that ryhmes with 'bota.
My .02. Don't kill the messenger.
/ Do I NEED or WANT a tractor? #10
You definitely need a 4wd diesel tractor with a loader.
Now do you need a backhoe? I don't know. I have one but I don't really need one but I get enough use to justify it ... at least so far. You can rent a hoe or mini excavator for about 200 a day. I don't know about putting in a pond with a small tractor mounted backhoe. I could dig a horse or cattle watering hole but a pond would be out of the question for my equipment. But there are a lot of potential uses.
As to mower deck. A tractor that takes a midmounted mower deck is going to be on the small size. 30 HP or so. But you could mow with a rear pto mower mounted on the 3pt hitch.
You didn't say how big your current mower is. If it can handle 2 acres, I say keep it and see how it goes
You can buy a new garden tractor mower for the price of my midmounted mower.
/ Do I NEED or WANT a tractor? #11
Everyone needs a tractor , but most havent realized it yet . TRACTOR : A toy that makes work easier and fun .
/ Do I NEED or WANT a tractor? #12
Another tack here, I moved to the country when I was in my low 20's. I needed a tractor but didn't get one for a few years. Then I bought a Ford 2N with no live pto, no loader, etc. I killed my back and the rest of my body fighting to get stuff done with inferior equipment.
Get a good modern tractor with a loader.
/ Do I NEED or WANT a tractor? #13
13 acres in North Alabama? 2 acres of lawn? Trails? Forest?
How is your back? Do you like lifting and lugging things for exercise? Will you be moving trees?
You don't NEED a tractor. People have existed for thousands of years without a tractor, or a computer. A basic 30 to 50 HP tractor, 4WD, w/ FEL, pallet forks, 3pt, drawbar will make many things much easier.
Hang around and see what we do with tractors other than basic farming. Keep a list of all the things you might want to do. Some things, like moving a 12' log onto a sawmill or pulling a 3 bottom plow require more HP than others. Most tasks can be done with a smaller tractor, it just takes longer.
Now the backhoe is a toy, but it beats the heck put of a shovel.
/ Do I NEED or WANT a tractor? #14
I did this (TO30 Ferguson), later sold it and did without, again, for several years.
Biggest mistake I made was I didn't get a tractor sooner.
Cheers.
:drink:
Finally bought a modern tractor with equipment and realize what a mistake it was to have waited so long. No more hiring things done or killing yourself trying to do things manually. The relief on my back is/was payment enough.
Only thing I'd add is what was mentioned about steep slopes and pictured in post #3 with the Steiner mower. I also have a large zero-turn for lawn care. However, if I had slopes or hill(s) like pictured I'd spring for a mower like that first, then buy a tractor if/when I could swing it. It's an expense to furnish a homestead property, but well worth the investment down the road. 50's, 70's, and 90's model tractors still pretty much bring their original MSRP, if you own it 20 years I don't see the future being much different. Wish that could be said for new $60,000 pick-ups. :bawling:
Thanks for the feedback.
Replacing the riding lawn mower is the top use for the tractor.
Since our house is on the hill side, there is a dirt ditch behind the house. This needs to be excavated every 1-2 years to prevent water from running onto/into the house.
I would like to dig up a stretch and put in a proper drainage. That job alone IMO requires a backhoe.
And for that job it needs to be a narrow tractor, as it is just enough space for a riding lawnmower to get through.
Maybe a B series Kubota?
/ Do I NEED or WANT a tractor? #17
Can you or would you be able to straddle the "ditch" with a compact tractor? if so a back hoe attachment would be advantageous...otherwise if the hill is steep on the high side of the ditch...a back hoe attachment on a tractor is not going to work efficiently...
A picture of the ditch/terrain would help everyone understand your needs a bit better...
/ Do I NEED or WANT a tractor? #18
I had a light-frame Kubota B3300 SU tractor-loader prior to my heavy-frame Kubota L3560. There is little difference in size between the two machines. With any light tractor, as soon as you start to do heavy work, Newton's Law of equal and opposite reaction comes into play. As soon as you dig with a Backhoe or a Toothbar on an FEL bucket, the tractor is pushed around. Standard tractors are laterally unstable. The two small front wheels and large rear wheels, which provide great mechanical advantage when pulling implements, do nothing for lateral stability.
On slopes it is very easy to roll a standard tractor. Very easy.
A heavy tractor, which will also have a wider stance, stays anchored better, but tractors are unstable on sloped ground, unless especially engineered like a Ventrac for slopes. The largest market for Ventrac and Steiners is golf coarse mowing, so you can be sure the riding mower will not be missed. The wheels are equal size, front and rear.
Unlike road vehicles, tractors have brakes only on the rear wheels. When going downhill, weight transfers to the small front wheels, so the rear wheels are unloaded, providing practically no braking. Therefore you must always have 4-WD engaged when going downhill, to have four wheel braking. Most of us keep 4-WD engaged at all times over dirt, shifting to 2-WD only when proceeding on a hard surface.
Tracked excavators have low ground loadings because of the tracks, and a low ground clearance by design. Also, the tracks provide multiples greater stability than the two small stabilizers which let down as part of a tractor Backhoe package.
Did you open the Ventrac LINK provided in Post #3 ?
/ Do I NEED or WANT a tractor? #20
If you are going to mow all 2 acres this means either a good ztr or several thousand for a mower $$$
If that is your only job for a backhoe you might want to consider renting a mini-ex or hiring the job out. Sunbelt rents them for about $1k/month.
Don't get me wrong, a backhoe is a great toy. I feel like a kid in a big sandbox every time I use mine, but I've put on less than 100 hours with it in the last 5 years. But to get
and something to handle trees will be difficult.
2014 Ford Econoline Van, VIN # 1FTNE1EW7EDA90564 (A61165)
2014 Ford...
PALLET OF MISC FLOOR BUFFER FUEL DOLLY (A62131)
PALLET OF MISC...
Chevrolet Tailgate Themed Wall Decoration (A61569)
Chevrolet Tailgate...
Spray King Pull Type Sprayer (A63116)
Spray King Pull...
Ingersoll Rand 185 Compressor (A64047)
Ingersoll Rand 185...
Teak Wood Table Top (A61569)
Teak Wood Table...
