Hour Meter Stuck CK20 HST
   / Hour Meter Stuck CK20 HST #1
CitizenOfThePlanet
I am hoping for some advice on how to fix a stuck hour meter. When I bought the tractor in 2013, the alternator went and somewhere during the process my hour meter stopped working at around 300 hours.
I am considering selling my CK20 to upgrade to an excavator for a project, but I am most likely going to keep it so I can use it for managing my goats. Either way I need to fix the hour meter. I spoke with a Kioti service guy and he said it could be a few things, but before I have it towed in to him to replace the cluster, I should try and troubleshoot it.
He said there should be a pink wire with a white tracer under the left foot where the black plastic box is mounted, and that the wire may be unplugged or broken. I can't find a single wire under that side, near that box.
He said that under the steering wheel or on the firewall there should be a black box that says "hours" on it. I can't find any such box.
He said it's most likely not the cluster because it happened around the time I changed the alternator.
Does anyone have any suggestions to help me fix this? Thanks a lot.
Sorry I forgot to mention that the tach works fine, and everything else on the tractor works great as it should, it's just the hour meter.
   / Hour Meter Stuck CK20 HST #3
My hour meter on my CK20 has also stopped, but I have not had time to dig into it just yet, too many other projects. Do you have the schematic, if not IM me and I will send you what I have.
Rancho
   / Hour Meter Stuck CK20 HST #4
Rancho
See my post in the PTO thread.
Rancho,
I have sent you a PM for the schematic. I appreciate the help. Does anyone have any ideas about what might be going on to cause this? Thanks a lot!
   / Hour Meter Stuck CK20 HST #6
Don't waste time and money trying to trace it, I highly doubt you find a fix. This has been discussed on several threads.
My 2003 CK20hst meter died at about 100. Determined there was a problem in the cluster, checked and had to replace whole cluster, back in 05 it cost over $300 for part only. went to internet to a site recommended by others here and found a very nice compact digital hour meter that has 5 logs, 4 resettable, one counts down to next oil change, non resettable is master, rest can be used for what ever service you want.
Oh price was under $50, two wire connection, took longest to find and cut hole for install, two wires, done in under an hour. Oh still works like new after over 1500 hrs.
Joe, I did consider wiring a new digital meter, but I am not sure yet if I am going to sell the tractor or not and figured the new owner would either want a new cluster, or a digital meter. I guess if I end up keeping it I will install a digital meter. It seems to me that this issue is very common with these tractors and it's a shame that Kioti doesn't cover the cost of fixing the issue.
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
Purple Martin Frame w/Pole & 8 Gourds (A56469)
Purple Martin...
2017 Caterpillar 259D (A53317)
2017 Caterpillar...
Preliminary Listing / Full Catalog Coming Soon! (A53317)
Preliminary...
(3) 24"x20' PVC Pipe (A56469)
(3) 24"x20' PVC...
2009 BMW 335i Coupe (A55853)
2009 BMW 335i...
