Keeping them shiny
/ Keeping them shiny #1
GreatWhitehunter
Eastern CT
JD 110 TLB
What have you guys found effective for restoring the shine and luster to the plastic parts of modern cuts?
My 110 has some black plastic that has faded out and I'd like to get it looking good. The tractor is stored out of the UV since I've owned it but was exposed to UV by the previous owner. I've tried armour all but looking for a more permemant solution.
Matt
/ Keeping them shiny #2
I bought a 20 yr old fiberglass bass boat that was in sad shape. After searching I came across form RV forums that suggested using Zep Wet Look floor polish to restore shine. I gave it a try and it worked very well. Now that is for fiberglass, I don't know how it would do on plastic. Worth a try though.
Shop Zep Commercial Wet-Look 128-oz Floor Polish at Lowes.com
As a last ditch effort you could repaint the black plastic with Krylon Fusion.
Fusion for Plastic® - | Krylon
/ Keeping them shiny #3
Hmmm, I have been looking for something to rejuvenate our travel trailer, may have to give that a shot. Poor finish is dull and chalky.
To the OP, I believe it's mothers that make a product called back to black. You use it while washing and it brings the plastic back, works pretty well and is pretty easy to find. Check out wallmart or the auto stores with the car washing and detailing products. Cheap enough to give a shot at least.
/ Keeping them shiny #4
As posted- Mothers Back to Black works pretty well .
I just went over some black trim with Wipe New and it seems to last a lot longer.
/ Keeping them shiny #5
Also, how do you apply the Zep for a fiberglass application?
/ Keeping them shiny #6
I found out, by accident, that Fluid Film really brings back the deep luster in paint and plastic. I wipe on a thin layer, let it soak in a bit, and then wipe it off with a dry rag. I first noticed how nice it made my truck look where I over-sprayed some FF while undercoating it a couple years ago. I wiped it dry and the 'spots' remained for months (or until I washed it which rarely happens). the spots looked better than the paint around them. I applied some to an old JD mower plastic body which was looking dull, and it looked much better. It seems to nourish the paint and plastic.
/ Keeping them shiny #7
First wash your travel trailer with Bar Keepers Friend (similar to Comet but without bleach). Scrub hard to make sure it is completely clean. Then just dampen a microfiber cloth with Zep and apply a thin coat. By the time you work your way around, the area you started will be dry if you applied a thin enough coat. It will take 3 or 4 coats before you start to see an improvement. I applied 5 or 6 to my boat. It goes quickly since you are wiping on a thin coat. No rubbing, no buffing, just a light wipe.
I don't have any before pics. Here is the after. It doesn't look showroom new but looks tons better than it did. Originally it was very chalky.
/ Keeping them shiny #8
Thanks for the tip on Mothers Back to Black. Will try that on our Jeep fenders.
Next up for the boat will be new carpet. :)
/ Keeping them shiny #9
Back to Black is good for restoring already faded parts. Aerospace 303 protectant is great for keeping them from fading in the first place!
/ Keeping them shiny #10
Krylon Fusion is a great product. I used it on the grill of our minivan several years ago. It has held up very well. If the black pieces are somewhat easy to remove or easily taped off so they can be sprayed I would recommend it as a first resort.
/ Keeping them shiny #11
Well looks like I'm gonna have to give the Zep a try. Thanks for the tip.
Aaron, let us know if the back to black works for ya. I have seen those wipes mentioned earlier as well just haven't used em myself. The other thing I've used on the bed rails of my truck is the Meguires interior dressing. Looks good but doesn't last very long, usually just a wash or two.
/ Keeping them shiny #12
I did this to my JD paint. The paint is faded, chipped, scratched and rusting. So instead of wax, I threw a quick spray of FF on the hood and wiped it down. It doesn't look new (doesn't hide scratches or rust!) but looks a heck of a lot better. Did the bobcat too.
Back-to Black works good, but doesn't seem to last long. The copious amount of black trim on my truck fades within a few months of application. I try to apply it every time I hand wax the truck, which is usually 2-3 times per year. But mid-way through the winter, its fading again. haven't found a better product though, as the rest of the store bought stuff seems to be worse.
/ Keeping them shiny #13
I keep the seat & arm rests clean & pliable using Pledge. Used it for 25+ years on my previous tractor and the seat never developed any cracks in the vinyl.
I was going to try the back to black as I heard that it worked, but I've got a ton of FF in the garage so I may as well try that first. Thanks
Matt
/ Keeping them shiny #15
Dakota Shine is supposedly pretty good as well. A tad expensive though.
/ Keeping them shiny #17
For plastic, a heat gun used carefully will do wonders. The plastic needs to be clean, then just go over the plastic with the heat gun. You will see the plastic return to the original color as you apply heat. Don't do too much at one time, you don't want to deform or melt the plastic and you can always hit it a second time if needed. It works really well and then you can always apply 303 to keep it looking good.
/ Keeping them shiny #18
If it's painted, I haven't found anything better yet than Zaino Polish. It is expensive but it takes so little that it lasts forever. I've literally done my entire care with less than 2 ounces which is how it's intended. To my knowledge, you can't buy it in stores but you may have a "rep" in your area that sells it. If not you can order directly from Zaino Bros website. I don't know if it's customary but the rep that I bought from always threw in extra polishing pads and goodies the more I bought. They have products for any part from glass to paint to tires to plastic and leather.
Other than the awesome shine, the other great thing is ALL of their stuff smells GREAT! REALLY! Their spray enhancer smells kinda like grape bubblegum to me. And the shine last forever and unlike wax, the more layers of polish you add, the shinier it gets and you can buff as hard as you can and it just gets shinier. I use to wash and polish my vehicles every week. The last time I bought a new truck I spent the whole weekend and washed it, clay barred it, washed it again and then put 6 coats of polish on it. I didn't wash it for over a year after that (life happens) and still had numerous people comment on how clean I kept my truck. I looked at them like they were crazy but looking at it again and I realized it still had an amazing shine even through the skim coat of dirt and dust.
Just talking about it makes me wish I had time to go baby it again!:eek: The worst part with a really dirty vehicle is using a clay bar but the finished results are amazing!
/ Keeping them shiny #19
I gave up worrying about the "shiny" part after about a year - living out here. We have so much dust and volcanic ash that within a couple days there will be a complete coating on any vehicle. When I feel "moved", I will pull the tractor out and hose it down good - then wash & wax it. Two days later it will, again, be totally covered with dust & volcanic ash. Covered or uncovered - garaged or not - - shiny just isn't a option out here. A good coat of wax will protect the finish and that's what I look for.
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
2007 Regal 30 Express Cruiser Boat with T/A Trailer (A61574)
2007 Regal 30...
2004 INTERNATIONAL RA027 4X2 S/A DAY CAB TRACTOR (A59911)
2004 INTERNATIONAL...
2025 Pabreak 6-Way 84in. Serrated Hydraulic Dozer Blade Skid Steer Attachment (A61567)
2025 Pabreak 6-Way...
2025 JMR 4x8 Forklift Safety Basket (A61572)
2025 JMR 4x8...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
