Using clutch as a brake?
   / Using clutch as a brake? #61
Using one brake to help turn works best with 'narrow front' tractors whose front wheels can usually turn much more sharply.
Also helps turn with a wide front end like yours has in a variety of conditions, like on hills, or when on wet grass, or with a heavy load on the rear.
Adjust both sides to evenness if you latch (who doesn't as default?) the brakes.
Most everyone, so far as I know. I've been driving tractors for about 65 years and have never heard of anyone leaving the brakes locked until I read a few people say that here. I use the brakes individually all the time, and only lock them when I want both to be engaged when the parking brake is set, or maybe when I take it on the road.
Terry
Son of man, these folks are doing a great job offering written advice but you, an inexperienced operator, are working with some equipment that can injure or kill in 100 different ways if not used safely. Getting some on-the-scene instruction from someone who knows tractors, mentioned earlier, is highly recomended.
I understand this is not a toy. I've spent some very valuable time over in the safety forum and go back there periodically to stay grounded. I also have a couple of friends with tractors who I ask whenever I'm not sure about something from a safety aspect.
one of them showed me how he gets his tractor unstuck by chaining the back rim to a tree. however, whenever I tried it myself, I was scared the tractor would flip over backwards since the front tires raised off the ground. however, 3 different people assured me it wouldn't flip over with the bush hog attached. so whenever one of my friends came over, I followed thru (against my reservations). Sure enough, the tractor came out safely. :)
Grandad makes an excellent point. If you don't know how to drive a manual, I'd guess you probably also aren't aware of a 100 different ways the tractor (and another 100 ways the bush hog behind it! ) can kill or injure. Please recognize you are a danger to yourself and all those around. Even the best, most experienced operator doesn't always see the 101'st way coming.
On the other hand, we all had to learn somewhere. Follow his advice.
I imagine there are many things I don't know. therefore, I try to take it slow, use good judgment and ask many questions!
A picture is worth a thousand words. You, an experienced operator and your tractor all together for a couple of hours would be worth even more. If the previous owner is nearby, is there a chance you could get him to come help you?
The article on pto safety linked below is a little off topic but would be worth reading.
Power Take-Off Safety | TractorByNet.com ? Compact Tractor Resource
my wife grew up on a farm so she knows way more than I do about tractors. but those 'ol glory days are pretty much behind her. lol the previous owner is nearby but I don't really know him like that. I only met him thru a local dealer who helped him sell it. he gave me some pointers concerning the bush hog. the rest has been on the job training. :)
FYI - anything relating to my safety is on topic as far as i'm concerned. thanks for the article! I wasn't aware of any of that. it was definitely a good read. I printed it out so I can refer back to it again.
Ain't nothing wrong with keeping them locked...different preferences and needs...in my case I've been riding on & driving tractors for about 45 years and never had the brakes locked.
- Hitting both with 1 foot has never been a problem, but I can see additional safety advantage for locking them for high speed travel.
Unlocked :
- Obvious turning advantage, if required.
- A very quick way to avoid getting stuck, keep momentum and get the tire with traction to propel by braking only the other tire that is slipping when you can't or don't want to slam in the differential lock.
i'm gonna have to remember that single brake tip. It seems like it's easier to get stuck the slower you travel b/c there is less momentum. I think I was in low gear both times I got stuck. my differential lock has come in handy a couple of times.
Neutral is just the condition of not being on one of the gears. You are always in neutral as you shift between gears.
As of "using" neutral, you do that when you want to let out the clutch with the engine running when you don't want apply power to the wheels. Like when you are stopped and want to pause for a minute with the engine running. But be aware that unlike Park in an automatic, nothing is keeping the tractor from moving. So unless the spot is dead level, you need to keep the brakes applied.
It's clear you don't understand how your machine works. As others have said, you really need some hands-on coaching from someone who knows how to operate a tractor like yours. It's a dangerous machine, especially with a rotary cutter, and used improperly you can seriously injure or kill yourself or others.
Terry
My tractor has a separate starting position and a parking brake so I don't understand why I would ever leave it in between gears in 'neutral' with my foot off the clutch?
   / Using clutch as a brake? #67
I don't understand "separate starting position."
You leave it in neutral when you are stopped with your foot off the clutch because if you don't it will either start moving or kill the engine. Setting the parking brake does not remove power to the wheels.
Terry
   / Using clutch as a brake? #68
So that you can be stopped without depending on your foot staying on the clutch.
Two reasons for this:
- Less wear on clutch (throw out bearing) if your not sitting there for an extended period of time with the clutch pushed in.
- Safety: Objects, animals or people around you don't depend on your foot not slipping off the clutch and the tractor suddenly moving.
If your transmission is not synchronized (JD 'collar shift', etc) you must come to a complete stop, but also wait for a few seconds before shifting and let the gears stop spinning to avoid the grinding sound.
Using one brake to help turn works best with 'narrow front' tractors whose front wheels can usually turn much more sharply. Differential lock (find yours ir you have it) can help you get unstuck, but applying brake to a spinning wheel can help there, and being in the lowest gear may be required since stopping one wheel will make the other turn twice as fast. Adjust both sides to evenness if you latch (who doesn't as default?) the brakes.
btw, about that pond ... mowing/hogging too close to the water limits wildlife activity that contributes to a balanced eco-system. Those who do so may have to feed fish to augment a narrow food chain and maintain a thriving population. One may have to choose between clear ground and shoreling/'buffer' maintenance. Size/depth of pond and access has much to do with how much of each you decide on to 'balance' the two. (I mow 12 of >2000 ft of shoreline. Managing the rest for wildlife cover is a complete job by itself... tho' more knowledge/experience than work after a while) tog
I'll try to make sure I wait a bit before changing gears. I practically never use high gear so unlatching the brakes seem more beneficial for my needs. I don't know if we have any fish in the pond I recently cleared? It's full of algae so I haven't yet tried to stock it. I know it has turtles. We have another pond in the back of our property that is still overgrown. I know for a fact it doesn't have any fish b/c it's currently dried up. lol
   / Using clutch as a brake? #70
If the engine can run, foot off the clutch, without the tractor moving, it is in neutral.
Bruce
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
New/Unused SD Lanch 20x30 All Steel Carport (A57454)
New/Unused SD...
10 - 3/16in Plate Steel Sheets (A55973)
10 - 3/16in Plate...
2020 Kia Soul SUV (A55973)
2020 Kia Soul SUV...
2022 Horizon Trailer (A55973)
2022 Horizon...
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
