Using clutch as a brake?
   / Using clutch as a brake?
Why do I get the feeling you're pranking us?
... But giving benefit of doubt: Use both brakes when you don't want one brake to spin the tractor sideways. That could be dangerous at higher speeds and tip tractor over.
You must push in the clutch to disengage the engine from turning the wheels every time you stop. Apply brakes only you will either: not stop. Or stall the engine as you've experienced.
Go find somebody that can teach you how to drive a manual and the concepts behind them.
Good luck.
no this isn't a prank. I had the tractor for almost a year. However i got stuck the first time I bush hogged so it sat for about 6 months until I was finally able to get it free. We had an unusually rainy year so my ground is finally hard enough to engage. So far I've managed to bush hog our 4 acre field twice and cut most of the overgrowth around the edge of our pond. I learn a little more each time I use it. I just want to make sure i'm not making bad habits that could eventually damage anything.
Anytime you want to stop press both brake pedals, but have the clutch pressed first if it is in gear.
I fully agree that it sounds like you would be wise to find someone with a fair amount of tractor experience who can come over to your place, get on your tractor and demonstrate some basics of tractor operation/safety for you. Be careful.
I thought you stated instead of using both brakes to slow down, you normally lower the throttle. So I was asking under what conditions would you use both brakes simultaneously without first pressing the clutch?
seems as tho you are comparing the tractor to a car with an automatic transmission.
that's exactly what i'm doing... A friend of mine tried to teach me how to drive a stick 20 years ago but I never really got the hang of it. Lol. So in my world, I simply press the brake to come to a complete stop.
   / Using clutch as a brake? #44
TractorData.com Massey Ferguson 1030 tractor transmission information
i am not coming up with any sort of sync transmission or like. on google. without knowing more of type of geared transmission.....
you should have 1 through 4 plus R shifter and then another lever for L/M/H (low / medium / high) for 12 forward gears and 3 reverse gearing options.
you should be able to shift between 1-4 by pressing in clutching and shifting to next gear.
unknown for L/M/H you may need to come to a complete stop before changing.
of course come to a complete stop before shifting between forward / reverse gear settings.
coming to a complete stop= always push in the clutch, and then brake. ((much like a manual transmission for a truck / car))
neutral = space between gears. were shift handle slides back and forth between slots for 1-4 and R (other words shifter not in a grove for one of the options = neutral) ((much like a manual transmission for a truck / car))
slowing down press in clutch AND/OR let off the gas / throttle peddle. ((much like a manual transmission for a truck / car))
--as clutch gets fully pushed in... press on brakes for quicker stopping. ((much like a manual transmission for a truck / car))
split brakes = moving your foot and leg around some. it is not tossing your leg down and being lazy. pending on were i place foot, i can nail both brakes at same time, or one or the other.
   / Using clutch as a brake? #46
Never. Well, maybe if you were in road gear and lowering the throttle setting wasn't slowing you fast enough, but I can't think of any time in normal operation.
You had better get the hang of it now, because that's what you have. :)
Terry
   / Using clutch as a brake? #47
You have a mechanical connection from the engine to the wheels through the clutch and transmission. If you use the brakes to stop the tractor, without using the clutch, what else do think the engine will do but stall? The clutch is used to allow the engine to run without transmitting power to the wheels. Pressing the clutch in removes the link between engine and wheels. Releasing the clutch links them back together. Once you remove the power from the wheels, the brakes can be used to stop movement as necessary. On a gear tractor such as you describe, the brakes are unnecessary to slow down because the engine and whole drive train is designed to keep the wheels moving at the exact same speed, *ALL* the time, for a given rpm. If you are just using brakes and no clutch, you are setting up a fight between the brakes and engine. Neither is going to win in the long run.
If your tractor stops "instantly" when you press the clutch, you must be traveling at extremely low speeds. I've never seen a tractor (or any vehicle really) that doesn't coast at least a few inches when the clutch is pressed. The exception would be if pulling something that offers great resistance (plow, stuck tractor, tree stump, etc.)
   / Using clutch as a brake? #48
Son of man, these folks are doing a great job offering written advice but you, an inexperienced operator, are working with some equipment that can injure or kill in 100 different ways if not used safely. Getting some on-the-scene instruction from someone who knows tractors, mentioned earlier, is highly recomended.
   / Using clutch as a brake? #49
Grandad makes an excellent point. If you don't know how to drive a manual, I'd guess you probably also aren't aware of a 100 different ways the tractor (and another 100 ways the bush hog behind it! ) can kill or injure. Please recognize you are a danger to yourself and all those around. Even the best, most experienced operator doesn't always see the 101'st way coming.
On the other hand, we all had to learn somewhere. Follow his advice.
   / Using clutch as a brake? #50
A picture is worth a thousand words. You, an experienced operator and your tractor all together for a couple of hours would be worth even more. If the previous owner is nearby, is there a chance you could get him to come help you?
The article on pto safety linked below is a little off topic but would be worth reading.
Power Take-Off Safety | TractorByNet.com ? Compact Tractor Resource
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E88NFB23656, Extended Cab, 4 x 4, 3.5 L EcoBoost Gas (A59076)
2022 Ford F-150 XL...
Bucket (A55973)
Bucket (A55973)
2017 Liebherr L566 X Power Wheel Loader, PIN# VATZ1484EZB044020, Liebherr Turbo Diesel Engine, Cr... (A59076)
2017 Liebherr L566...
2013 Dodge Durango (A53317)
2013 Dodge Durango...
2012 DOOSAN G25KW GENERATOR (A55745)
2012 DOOSAN G25KW...
