BX25 Backhoe Bucket Pin Stuck
   / BX25 Backhoe Bucket Pin Stuck #1
HeLa
Gold Member
Hunterdon County, NJ
Kubota BX25 TLB
I went to remove my BH bucket, with plans to install my ripper tooth. The first pin came out like expected, but the second wouldn't budge. I tapped on it lightly with a copper rod, no effect. Nothing LOOKS visible damaged or bent but I'm sure it wouldn't take much.
I'm wary to force the pin out, if that's even possible, with more force in case.
Are these pins known to bend? Suggestions? Experiences?
   / BX25 Backhoe Bucket Pin Stuck #2
I had the same issue with a B2620. Got a BIG hammer and a big drive pin punch. don't hit the BH pin head, it will
"mushroom" .
"mushroom" .
thanks. out of curiosity, were you able to re-use the pin or did you replace it?
   / BX25 Backhoe Bucket Pin Stuck #4
Oh, I reused the pin. The use punch to move the pin, and it will prevent any damage. I have learned quite a bit in one year, mostly that the tractor can do A LOT! and so can I. After that, I have learned that grease and lubrication helps. And just this morning, I learned NOT to read threads about tipping over.
   / BX25 Backhoe Bucket Pin Stuck #6
they shouldn't mushroom as they are hardened wear pins.
Not sure about that,,,,, One bucket pin I had to cut out on my mini-excavtor - cut like butter. It was the softest steel I ever cut. They do that so the pin wears instead of the bore, protecting the more expensive and difficult-to-repair components. The pin is (normally) easy to replace, and low cost.
You don't want to mushroom the end because with a fat end it will be just that much more difficult to pound out. You have to arrange your punch such that you pound it only near the center (don't pound near the edges!). If it does mushroom some, grind off the larger diameter before you put it back in.
It shouldn't be that hard to get out. All the greased interfaces will slide easily. The non-greased interfaces need to be lubed with a penetrating oil such as Liquid Wrench, or PB Blaster. Or any light oil, such as diesel with a little oil mixed in. Post a pic of this pin that won't come out, maybe someone can see the problem in your pic.
   / BX25 Backhoe Bucket Pin Stuck #7
Not sure about that,,,,, One bucket pin I had to cut out on my mini-excavtor - cut like butter. It was the softest steel I ever cut. They do that so the pin wears instead of the bore, protecting the more expensive and difficult-to-repair components. The pin is (normally) easy to replace, and low cost. You don't want to mushroom the end because with a fat end it will be just that much more difficult to pound out. You have to arrange your punch such that you pound it only near the center (don't pound near the edges!). If it does mushroom some, grind off the larger diameter before you put it back in. It shouldn't be that hard to get out. All the greased interfaces will slide easily. The non-greased interfaces need to be lubed with a penetrating oil such as Liquid Wrench, or PB Blaster. Or any light oil, such as diesel with a little oil mixed in. Post a pic of this pin that won't come out, maybe someone can see the problem in your pic.
This is a pin out of the front end loader on my bx25 it snapped while digging/loading rock. took it to the dealer an he said that it is odd for the pins to break cause they are hardened. I asked if I could get a better/stronger one an he said they are all made out of the same material. If you run a file across it it doesn't cut easily. Notice it broke in the grease valley. image-253415551.jpg Might just be a gimik to make more money
thanks all. i'll pound on it a bit harder this weekend and see what happens.
   / BX25 Backhoe Bucket Pin Stuck #10
Thank you for explaining it. My experience is that what shouldn't happen does, what should be easy isn't, and why take the chance? Lub, grease, and penetrating oil. And the help of others. Priceless.
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
Adams Tender / Magnolia Trailer (A56436)
Adams Tender /...
207273 (A52708)
207273 (A52708)
2014 International Maxxforce DT (A53317)
2014 International...
