sixdogs
Super Star Member
- Joined
- Dec 8, 2007
- Messages
- 15,795
- Location
- Ohio
- Tractor
- Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Still unable to post a picture so try to visualize. I'm building a light duty cultivator and have some 2" x 2" equal angle iron that's 3/8" thick and 7 ft long. It has a line of 3/8" holes punched an inch apart the length of it. The problem is, the guy that got these first had other ideas and cut the pieces in half.
Then he re-welded them but got the pieces crooked and I need to start over.
My plan is to cut them in half again on the weld and then weld again but get things straight. Since I need to get the holes spaced correctly I plan to use a short length of the same stock that I have and bolt the two pieces to this. It will assure the holes will line up plus will stay flat as I weld it.
The question is, what can I put between the pieces to keep any weld from sticking to the spacing piece? Is it copper, brass aluminum or all of them? Since the surface will be tight together, a thin sheet would do it. I've never done this.
Also, since I'm bolting the two halves to the spacing piece, can I just weld one side and then flip it over or will the heat try to warp it and should I do something different?
