What material does a weld not stick to?
/ What material does a weld not stick to? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Still unable to post a picture so try to visualize. I'm building a light duty cultivator and have some 2" x 2" equal angle iron that's 3/8" thick and 7 ft long. It has a line of 3/8" holes punched an inch apart the length of it. The problem is, the guy that got these first had other ideas and cut the pieces in half. :eek: Then he re-welded them but got the pieces crooked and I need to start over.
My plan is to cut them in half again on the weld and then weld again but get things straight. Since I need to get the holes spaced correctly I plan to use a short length of the same stock that I have and bolt the two pieces to this. It will assure the holes will line up plus will stay flat as I weld it.
The question is, what can I put between the pieces to keep any weld from sticking to the spacing piece? Is it copper, brass aluminum or all of them? Since the surface will be tight together, a thin sheet would do it. I've never done this.
Also, since I'm bolting the two halves to the spacing piece, can I just weld one side and then flip it over or will the heat try to warp it and should I do something different?
/ What material does a weld not stick to? #2
I have some 1/4" x 4" copper electrical buss bar that I use for jobs like this. I have some aluminium bar as well but always grab the copper. It carries the heat away and normal 6011, 7014, etc won't stick to it.
Can you shorten them by 1" to get a nice square end when you cut the old weld out? This would still keep the 1" spacing...
/ What material does a weld not stick to? #3
It would be better to use spacers so your weld is away from the backing piece. Ed
Yes, I could cut it square. Am going to MIG weld it.
How thick of a spacer? I like that idea better.
/ What material does a weld not stick to? #5
I try to keep the weld tight to the copper so it removes the heat and gives a flat surface to the steel where it meets the copper. If you use spacers then you could use a steel backing plate then grind it smooth...
/ What material does a weld not stick to? #6
Steel weld won't stick to aluminum. I've made welding fixtures from alum and the welding splatter doesn't stick to it.
/ What material does a weld not stick to? #7
Copper works very well. Use it all the time filling in old bolt holes or pin holes that are wore out so I can re-drill them.
I don't like aluminum. Mig weld will stick to it, and it will melt and just be an ugly mess.
/ What material does a weld not stick to? #9
How thick of a spacer? I like that idea better.[/QUOTE]
Almost anything, 1/4" would work fine, just needs to be thick enough to give you some space. Ed
/ What material does a weld not stick to? #10
Keeping it straight will be the challenge. How much tolerance do you have?
/ What material does a weld not stick to? #11
Copper plate for backing then tack weld it alternating the locations to keep the angle straight. It is going to be a challenge to keep it straight. Bolting the other angle to the one you are welding might help a bit to keep the welds from drawing too much but you still need to weld opposite side from the bend as the previous weld cools it is going to contract and pull the angle.
Shield Arc might can explain it better.
/ What material does a weld not stick to? #12
Oh I don't have the words to explain how to do it. I can show you how tho.:D
Angle iron, as with square tube is easy to bring back straight after welding.
/ What material does a weld not stick to? #13
Copper works fine, unless you are welding copper. :thumbsup:
2000 Mack CH613 Dump Truck (A59213)
2000 Mack CH613...
2017 Western Star 4700 Tri Axle Dump (A62613)
2017 Western Star...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 Land Rover LR2 AWD SUV (A61574)
2014 Land Rover...
Kubota L4802 DT LA766 Backhoe (A63688)
Kubota L4802 DT...
