2015 Hay Season
/ 2015 Hay Season
That is something I have not thought about. Thanks
I have raked few times with my pickup,so I didn't have to switch anything works fine. I have also used my side by side. Back when I helped a guy in my younger days we always used his dually to rake with,just don't run over the windrows with pickup hay could get somewhere like in the cat and start a fire.
/ 2015 Hay Season #353
The orientation of my field and having a pull type haybine would make a pull type better in the fact my wife or son could rake while I'm still cutting. I will have to give this some more thought.
Thanks...
/ 2015 Hay Season #354
The orientation of my field and having a pull type haybine would make a pull type better in the fact my wife or son could rake while I'm still cutting. I will have to give this some more thought. Thanks...
How many acres are you baling this year? I have about 15 I could bale and am thinking small squares because almost no one around here does them anymore and I'm always talking to people who ask where to get some, just not sure I want to mess with selling them.
/ 2015 Hay Season #355
My own field is 5 acres, the one across the street is 6 and another I do is 4. All very close just country roads to deal with and very little traffic. I don't really want to get in the hay selling business. I'd rather get more cows and use it myself.
/ 2015 Hay Season #356
Foreman, and farmer, Do you dislike the 3 point type because of transporting it? 99% percent of the time it will move from my barn to my field. Do not plan on any other use. If there is another reason I would sure like to know before buying one. Thanks.
Cat. While 3pt has its place and isn't terribly hard to hookup it's harder and more time consuming to hookup than a pull type. I never cared what hitch something had on it till we got our current cutter. It has a specific order to hookup if you try to hookup the other side first forget it you won't get both sides on. Why I don't know.
So now anytime I have a choice I go with pull type. They're easier to hookup and faster. Kids and wife can swap equipment by themselves if they have to.
/ 2015 Hay Season #357
Ok
Thanks farmer.
/ 2015 Hay Season #358
It finally got dry enough that I was able to get a cutting in last month. (early July) Did OK. 176 rounds (4x5) from 52 acres.
We haven't had measurable rainfall since. Now, it's so dry the grass has stopped growing. I cut the 12 acre Coastal Bermuda field yesterday, and I'm sure it will bale this afternoon. Just wont be much of it.
If we don't get significant rainfall soon, my 2015 hay season my be over. :eek:
/ 2015 Hay Season
Guy down the road asked me to bale his 12acres wasn't real good but wasn't real bad. So I drive over today and talked to him and suggested for what it would cost me to bale it with a minimum he could buy hay and run cows on his. I just couldn't keep my mouth shut and do it cause I thought was a better suggestion,he decided to buy hay and run cows,was I wrong for persuading him this way?
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
Giyi GY-STB47 QA Telescopic Boom (A60463)
Giyi GY-STB47 QA...
2003 PETERBUILT PB330 DUMP TRUCK (A58375)
2003 PETERBUILT...
CFG Industrial H12R (A60463)
CFG Industrial...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
Hydraulic Breaker Excavator Attachment (A60352)
Hydraulic Breaker...
