cat fever
Elite Member
Takes couple minutes get hooked up to a pull type and I can leave my cutter on also while pull the rake. You can pull it with pickup if need be.
That is something I have not thought about. Thanks
I have raked few times with my pickup,so I didn't have to switch anything works fine. I have also used my side by side. Back when I helped a guy in my younger days we always used his dually to rake with,just don't run over the windrows with pickup hay could get somewhere like in the cat and start a fire.
The orientation of my field and having a pull type haybine would make a pull type better in the fact my wife or son could rake while I'm still cutting. I will have to give this some more thought. Thanks...
How many acres are you baling this year? I have about 15 I could bale and am thinking small squares because almost no one around here does them anymore and I'm always talking to people who ask where to get some, just not sure I want to mess with selling them.
Foreman, and farmer, Do you dislike the 3 point type because of transporting it? 99% percent of the time it will move from my barn to my field. Do not plan on any other use. If there is another reason I would sure like to know before buying one. Thanks.
Cat. While 3pt has its place and isn't terribly hard to hookup it's harder and more time consuming to hookup than a pull type. I never cared what hitch something had on it till we got our current cutter. It has a specific order to hookup if you try to hookup the other side first forget it you won't get both sides on. Why I don't know.
So now anytime I have a choice I go with pull type. They're easier to hookup and faster. Kids and wife can swap equipment by themselves if they have to.
