motorhome convert to pickup
/ motorhome convert to pickup #41
I have seen a ford camper to flatbed conversion before. I dont know who did the actual conversion, but they did a really good job of closeing in the back of the cab. What they did was found a old ford truck, of same year, and cut the back of the cab off and welded it to the camper cab. If you didnt know it was a conversion, it was hard to tell it wasnt a original ford truck cab. They built a flatbed and put on the chassis and made a really good hauler. A chevy van might nto be as similar to a regular cab as the ford cab was, so it might not be as easy . As for the chevy camper, I think you will find that the rear axle is actually a little narrower than a standard dually axle. Not as wide as a standard dual wheel ton truck either. This is going to make it harder to put a dually bed on unless you use adapters/spacers. This will vary according to year, but something you need to measure before spending money. As long as you can do the body work, converting it to a flat bed isnt that bad of a job, but paying for body work might make it un-economical.
the van cab is NOT going to stay.. I am a pick up guy and I want the cab space mostly so I can put my office back there and or crawl in and take a nap!
priorities:
1 get camper body off & floor off
2 get fuel pump rubber hose thingy fixed without dropping tank (again)
3 test drive and check for dependability for a month or so (2 x 55 gallon barrels of water for traction)
4 remove van body and install pickup body (I dont care. I will do the paperwork.. vans suck)
5 install flatbed (angle iron & expanded metal welded)
6 install sliding removable 5th wheel hitch & goose neck hitch & reese hitch
/ motorhome convert to pickup #43
priorities:
I didn't know you were getting rid of the van body. Are you sure this is possible? I thought the steering was different, you are pretty much sitting on top of the front wheels in a van, the engine is beside you. Lots of things are different.
I hate working on vans, some things are not very accessible. But look at all the cargo space you gain by putting your self up front with such a short hood, and all that area behind you for all types of uses.
yes I will have to change the steering box and shaft but I can get it off the truck that I get the body from. I hate working on vans too.
they suck...
and if cargo space is any kind of issue, I am pretty sure that I could pull a trailer without any issues.
I just found out that a buddy of mine had a seizure and cant drive so he is selling me his early 90's chevy 2500hd.
/ motorhome convert to pickup #45
I would suggest take the van put the back on it and sell it and then buy a pickup of your choosing,
/ motorhome convert to pickup #46
That ain't no fun. Projects are for fun and to make something useful.
hugs, Brandi
/ motorhome convert to pickup #48
I have not tried a van to pick up conversion, but the few "conversions" I have tried, were a lot more complex and expensive than ever expected, more problems than ever expected,
your talking about reliably, and usability, if you wanted to swap parts (engine etc.), I could under stand that, but your biting off a big chunk, and looking for a lot of challenge,
/ motorhome convert to pickup #49
son and I are cutting down a 70's motor home and are making a car carrier out of it.. What you are about to do is a piece of cake and should be fun.. Winnebago-1968.jpg
/ motorhome convert to pickup #50
'Atta girl.
:laughing::laughing::laughing: I really don't understand folks that tell others they shouldn't do a project. That just makes me more determined to do it.
hugs, Brandi
I will not be able to get anything more than scrap price for the motorhome.
and this project is too easy not to do... 80% labor.
The parts wont cost that much.
have you priced a 1990 chevy 3500hd pickup with less than 30 thousand miles?
I cant afford to buy one. and I dont need to buy one... I have one.. just a couple days of work when it stops friggin raining here in florida!!!
/ motorhome convert to pickup #52
If you wanted a little fancer look see if the van cab is the same as the van, (my guess it is), and find a old van and cut off the back for the rear of the cab, and then put a flat bed or small dump box on it,
Yeah, he could get the back 5 ft of the van body and add that to it and build in a sleeper cab on it for those long hauls! :) Lots of possibilities here lol.
/ motorhome convert to pickup #54
this is why I have not posted any updates.
this is why I cant get any friggin work done!!!
Steve,
Be careful what you wish for. We had floods like that over the Memorial Day weekend. We haven't had any rain worth counting, since then.
hugs, Brandi
/ motorhome convert to pickup #55
My grandpa has an old rv that he paid $200 for. It has a 440 gas motor. We already tore it down to the frame. We sold the scrap aluminum for more than $200. He was thinking about doing the same thing, but it would be a waste of time. He has better trucks. He has a rollback, three 5 ton army trucks, a forestry fire truck, and a ford F800 bucket truck. He has more trucks, but the most likely candidate for a dump truck is the international fire truck. image-2725711618.jpg image-3411658815.jpg image-173605070.jpg image-1938137482.jpg image-3463977634.jpg image-3165196125.jpg image-917004319.jpg image-1714820658.jpg
Steve,
hugs, Brandi
awwww.... I got hugs....
/ motorhome convert to pickup #58
My grandpa has an old rv that he paid $200 for. It has a 440 gas motor. We already tore it down to the frame. We sold the scrap aluminum for more than $200. He was thinking about doing the same thing, but it would be a waste of time. He has better trucks. He has a rollback, three 5 ton army trucks, a forestry fire truck, and a ford F800 bucket truck. He has more trucks, but the most likely candidate for a dump truck is the international fire truck. <img src="http://www.tractorbynet.com/forums/files/build-yourself/435208-motorhome-convert-pickup-image-2725711618-jpg"/> <img src="http://www.tractorbynet.com/forums/files/build-yourself/435209-motorhome-convert-pickup-image-3411658815-jpg"/> <img src="http://www.tractorbynet.com/forums/files/build-yourself/435204-motorhome-convert-pickup-image-173605070-jpg"/> <img src="http://www.tractorbynet.com/forums/files/build-yourself/435207-motorhome-convert-pickup-image-1938137482-jpg"/> <img src="http://www.tractorbynet.com/forums/files/build-yourself/435210-motorhome-convert-pickup-image-3463977634-jpg"/> <img src="http://www.tractorbynet.com/forums/files/build-yourself/435211-motorhome-convert-pickup-image-3165196125-jpg"/> <img src="http://www.tractorbynet.com/forums/files/build-yourself/435205-motorhome-convert-pickup-image-917004319-jpg"/> <img src="http://www.tractorbynet.com/forums/files/build-yourself/435206-motorhome-convert-pickup-image-1714820658-jpg"/>
It looks like one army truck has a cane am i right?? I like the firetruck
/ motorhome convert to pickup #59
Go for it but my bet is that when it comes to putting the PU body on so that you can make it street legal you will end up selling it all as scrap. I think it is going to be more to it than you think. :2cents: Ed
/ motorhome convert to pickup #60
He has three army trucks. Two have a boom, and one just has a semi hitch. The boom is rated to lift 20,000 at the closest point. It will lift 4,000 pounds at 18 feet away. Those trucks have a sweet winch. The front winch is 20,000k the back is 45,000k
John Deere 329E High Flow Compact Track Loader Skid Steer (A61567)
John Deere 329E...
832752 (A61166)
832752 (A61166)
Husqarvana Riding Mower (A56857)
Husqarvana Riding...
2014 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR1EH765285 (A61165)
2014 International...
2022 Schulte 2500 Giant Rock Picker (A56436)
2022 Schulte 2500...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A60352)
2019 Allmand...
