motorhome convert to pickup
/ motorhome convert to pickup #41
I have seen a ford camper to flatbed conversion before. I dont know who did the actual conversion, but they did a really good job of closeing in the back of the cab. What they did was found a old ford truck, of same year, and cut the back of the cab off and welded it to the camper cab. If you didnt know it was a conversion, it was hard to tell it wasnt a original ford truck cab. They built a flatbed and put on the chassis and made a really good hauler. A chevy van might nto be as similar to a regular cab as the ford cab was, so it might not be as easy . As for the chevy camper, I think you will find that the rear axle is actually a little narrower than a standard dually axle. Not as wide as a standard dual wheel ton truck either. This is going to make it harder to put a dually bed on unless you use adapters/spacers. This will vary according to year, but something you need to measure before spending money. As long as you can do the body work, converting it to a flat bed isnt that bad of a job, but paying for body work might make it un-economical.
the van cab is NOT going to stay.. I am a pick up guy and I want the cab space mostly so I can put my office back there and or crawl in and take a nap!
priorities:
1 get camper body off & floor off
2 get fuel pump rubber hose thingy fixed without dropping tank (again)
3 test drive and check for dependability for a month or so (2 x 55 gallon barrels of water for traction)
4 remove van body and install pickup body (I dont care. I will do the paperwork.. vans suck)
5 install flatbed (angle iron & expanded metal welded)
6 install sliding removable 5th wheel hitch & goose neck hitch & reese hitch
/ motorhome convert to pickup #43
priorities:
I didn't know you were getting rid of the van body. Are you sure this is possible? I thought the steering was different, you are pretty much sitting on top of the front wheels in a van, the engine is beside you. Lots of things are different.
I hate working on vans, some things are not very accessible. But look at all the cargo space you gain by putting your self up front with such a short hood, and all that area behind you for all types of uses.
yes I will have to change the steering box and shaft but I can get it off the truck that I get the body from. I hate working on vans too.
they suck...
and if cargo space is any kind of issue, I am pretty sure that I could pull a trailer without any issues.
I just found out that a buddy of mine had a seizure and cant drive so he is selling me his early 90's chevy 2500hd.
/ motorhome convert to pickup #45
I would suggest take the van put the back on it and sell it and then buy a pickup of your choosing,
/ motorhome convert to pickup #46
That ain't no fun. Projects are for fun and to make something useful.
hugs, Brandi
/ motorhome convert to pickup #48
I have not tried a van to pick up conversion, but the few "conversions" I have tried, were a lot more complex and expensive than ever expected, more problems than ever expected,
your talking about reliably, and usability, if you wanted to swap parts (engine etc.), I could under stand that, but your biting off a big chunk, and looking for a lot of challenge,
/ motorhome convert to pickup #49
son and I are cutting down a 70's motor home and are making a car carrier out of it.. What you are about to do is a piece of cake and should be fun.. Winnebago-1968.jpg
/ motorhome convert to pickup #50
'Atta girl.
:laughing::laughing::laughing: I really don't understand folks that tell others they shouldn't do a project. That just makes me more determined to do it.
hugs, Brandi
2007 Ford Crown Victoria Sedan (A59231)
2007 Ford Crown...
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2024 GREAT DANE FREEDOM LT FLATBED TRAILER (A59823)
2024 GREAT DANE...
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
Champion Vibratory Roller (A60462)
Champion Vibratory...
