DIY Mini Digger
/ DIY Mini Digger #1
Colcreate
Member
Cheshire, UK
none
I have a few projects planned around the home where a mini digger would be useful but I'm on a really tight budget and need to spread the expenditure over time. Hiring a machine several times a year would be too expensive so after looking at some of these homebuilt backhoes I thought I would have a go at building my own.
OK that's what I told the wife, truth is I just really wanted to build a digger and I had a pair of old Land Rover axles in my workshop and some steel channels that were going for scrap.... 4wd backhoe?
So here is how I have started...
Strip and clean the axles which will be cut and narrowed.
No plans or drawings, not even a sketch just going to make it up with what falls to hand.
/ DIY Mini Digger #2
I've seen three types of homemade "mini-diggers."
1. Two legs and two wheels that change locations for towing or for digging.
2. Four wheels, engine and booms rotate like an excavator.
3. Old truck frame, with old, small tractor backhoe mounted on rear, front axle may be in place with a steering tongue, or replaced with a rigid tongue for towing. Pump may be powered by the truck engine, which remains in place for weight and pump driving.
If you had two front axles, that would allow a better turning radius, and the ability to move sideways at an angle.
Bruce
/ DIY Mini Digger #3
Looking forward to see it running!
Here is mine I built from scrap:
I started building it with my dad with 10 years old and finished it with 18 years old. So don't worry about time as long as you get it running :)
/ DIY Mini Digger
I'm thinking along the lines of a tractor type vehicle. Simple but strong chassis, rigid rear axle with a pivot mounted front steering axle. Front end loader bucket with optional forks and a rear mounted backhoe.
I agree two front axles would be great for manoeuvrability or even an articulated chassis steer but I'm happy to keep this simple and run with what I have to hand. Here's the axles being narrowed.
I've cut 8 5/8" out of the long side of the rear axle to match the short side. I can use another short half shaft here. The front axle is offset differently so I've cut and welded the long halfshaft to keep the overall widths the same at about 4ft.
PTSG your digger looks awesome! So many questions... Do you have a build thread somewhere or link to more pictures?
/ DIY Mini Digger #5
Ask whatever you need to ask! :) I don't have a build thread but I can post whatever picture you need here, if you don't mind.
/ DIY Mini Digger
Chassis layout with narrowed Land Rover S2 axles, Suzuki transfer box and a Range Rover prop shaft.
The 6ft steel channels are 5" deep and fairly heavy so plenty strong enough for this job. The wheel/tyre on full lock has determined the width of the chassis rails.
/ DIY Mini Digger #7
Looks like this project won't be dragging on for months at this rate. :)
I've never seen heavy-duty clamps like those in your axle shortening photos. They look much more rigid than C-clamps.
If you tap your keyboard space bar after each photo attachment, they will be easier to see and select.
Bruce
/ DIY Mini Digger
Bruce
They are Carver Rack clamps made in the UK specifically for welding and fabrication. The clamp thread is shielded to avoid spatter, best clamps around but expensive. I'm a time served sheet metal worker but have been off the tools for 20 odd years.
/ DIY Mini Digger
A few more pic's, rear axle tacked in place and rear cross member welded
Need to figure out the front crossmember and axle pivot. The chassis rails at the front are spaced with a temporary brace.
/ DIY Mini Digger
Front axle pivot, the diff housing is still slightly off-set so I've shaped the end of a piece of 4" x 1/4" box section to fit the contour of the casing. I have some 2" round bar that I can turn bushes from for all the pivot points and some EN8 bar for pins. Might need some radius arms but will see how it looks when it's rolling.
I will cut the box section down, radius the top and weld it in place on top of the axle casing.
/ DIY Mini Digger #11
Hi Cheshire east or west? then north or south?
I am very near to proposed HS2 hub station
Also cheshire based and following with interest.
/ DIY Mini Digger
I'm North of you nearly as far as you can go and still be in Cheshire then a bit to the East...
/ DIY Mini Digger
Pivot bush cut to length, pilot bored ready to be test fitted.
I will bore it out and ream it to suit a 30mm EN8 pin once I have made the cross member and support bushes.
/ DIY Mini Digger #14
In tbn world terms, you two are practically neighbours. I'm down the A49, half a mile South of the Cheshire border.
Some neat work there Colcreate. :thumbsup:
/ DIY Mini Digger #15
Stockport/ Disley/ High peak way? Plenty of rocks up there
lovely Crewe for me!! soft sandy loam
/ DIY Mini Digger
Few more bits.
I spun up a bit of steel plate on the lathe and made an adapter to mate the Suzuki transfer box directly to the Land Rover rear axle.
With the Suzuki box in place and the Range Rover propshaft pointing forward I can now position the front cross member.
/ DIY Mini Digger
Here's the chassis layout!
The front axle is just hanging from a temporary pin while I chopped out the chassis rails to give travel clearance and yes that's a cable tie holding the transfer box.....
I've part drilled through the cross member with a hole saw both sides so I can finish it off properly when I've made the bushes and pin. Just wanted to get it set up temporarily to see what it looks like.
/ DIY Mini Digger #18
subscribing to your thread. so i can make sure i catch updates as you work through the build.
going to be intrsesting to see how ya manage to hook up the engine to the setup you have going on there.
/ DIY Mini Digger
Oh yes I forgot to mention at the start, this will be driven by a hydraulic motor!
It won't win any races, I calculate around 7mph but it will have 2wd, 4wd and low ratio with loads of torque.
As long as it can move around at walking pace while carrying/towing a load I will be happy.
/ DIY Mini Digger #20
Sounds like a dueable speed. But you may not want to put it on the road at all. My tractor that Goes 10mph or so is still too slow for the roads
2014 Chevrolet Sonic Sedan (A61574)
2014 Chevrolet...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
2008 CATERPILLAR D4K XL CRAWLER DOZER (A64279)
2008 CATERPILLAR...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A63689)
Midwestern...
213119 (A64276)
213119 (A64276)
