Wood selection for outdoor chairs
/ Wood selection for outdoor chairs #1
Garandman
Elite Member
Mount Sunapee NH / Dorchester, MA
Kubota L3200 HST
i might build some Adirondack chairs, or buy them. Either way I could make them from Pine, Poplar, Red Oak or Red Cedar.
This will sit down by the stream bank, possibly year round. I can coat them with something, but what is going to last the longest?
/ Wood selection for outdoor chairs #2
In order of longevity IMO
1 (longest) Cedar
2 treated pine
3 poplar coated with something
4 red oak
I wouldnt want to make them with red oak. its heavy, and not real rot resistant. White oak would be a better choice, but still heavy.
The rest isnt gonna be much difference in weight. For just doing chairs and not a whole lot of lumber, I'd lean toward cedar. You can also get treated pine that is "cedartone" that has a reddish look like cedar for a little less money. But I dont think a few chairs is gonna break the bank if done in cedar
/ Wood selection for outdoor chairs #3
1 (longest) Cedar
2 treated pine
4 red oak
+1. Cedar is my preference for outdoor furniture and structures. It is easy to work with, light and holds up well. It's one issue is that it is a soft wood, but other than that it is great.
/ Wood selection for outdoor chairs #4
cedar would be a good choice. I would go the distance and add an epoxy. I am a fan of the West system (105 and 207) and use it quite a bit. They have an awesome metering kit for doing smaller batches. My latest project is getting epoxied to seal it plus a couple coats of Schooner Gold varnish to add uv protection.
WEST SYSTEM | The 105 System of Epoxy Resins and Hardeners
http://www.yachtpaint.com/usa/diy/products/varnishes/schooner-gold.aspx
/ Wood selection for outdoor chairs #6
There are lots of different kinds of "Pine". Ponderosa pine won't last more than a few years, for example. Pine shelf boards from the store could be Ponderosa.
There are differences in Cedars too, some better than others for ground contact, but Cedar is generally good for outdoor chairs. If you don't want them to be too heavy, that's another huge benefit of Cedar. I have some cedar Adirondaks on my wood porch and they get moved around whenever we squeeze more chairs out there. They have a LOT of wood in them and could be very heavy if made of a heavy wood. If too heavy would beat up the porch too.
There are a lot of "chair plans" available but they are not ALL comfortable, you need to sit in them before committing to build. I found some Adirondaks, at a dept store that "fit" real nice (very comfy) bought one and copied the pattern (made 4 chairs).
I made changes here and there such as:
- used 1" thick Cedar
- widened the armrests
- "beveled" each slat
Beveling the slats increased the comfort a LOT. I convexed the horizontal slats & concaved the verticals with a tablesaw. Just slightly, just enough to make the corners go away. Mine are more comfy than the pattern chair from the store.
I made these to last, I bet they're still good when I can't get out of one anymore, and that may be awhile. ;) Mine need a little lateral bracing though, I might add that someday (maybe hide some braces underneath, made out of a hardwood).
One fella says "ride hard or sit on the porch". My favorite thing(s) to do is "ride hard then sit on the porch" :laughing:
Sitting by the stream would be OK too. :cool:
/ Wood selection for outdoor chairs #7
ddbackhoe.
That is beautiful! Is it cedar after the West epoxy and varnish?
/ Wood selection for outdoor chairs #8
I use cypress for outdoor furniture. Have a bench that's been outside for 3+ years and is still looking great. Cypress trees grow like weeds around here, but I can't cut a live one since they are bald eagle habitat trees. But when one falls during a storm, the chainsaws come out. Best are ones that get "topped" in storms. Let them stand for 2-3 years and when I cut the tree down, the wood is already dry and seasoned. It mills, saws, and works like butter, with nice tight grain. Here's a freshly milled beam that was cut from a standing dead tree:
Here's a bench made from cants and scrap pieces of cypress that came off the beams:
Next on my list would be cedar. But don't overlook using synthetic lumber -- like that trex type decking. I see a lot of outdoor furniture made from that stuff now.
/ Wood selection for outdoor chairs #9
I would agree on the two suggestions to use cypress. It makes absolutely beautiful outdoor furniture and is more durable than cedar. Very easy to work with and takes a stain nicely. I left mine raw for a few years, but then sanded them down and put clear preservative with a small amount of golden oak stain on it and it looks great.
/ Wood selection for outdoor chairs #10
I built two Adirondack chairs way back in '83. There are made of red oak because no other hard wood is readily available. I slop them down yearly with a good preserving oil stain and they are still good as new.
I think this is mainly due to our extreme low humidity and I have all four legs sitting up off the ground on a fire brick.
Since I built them, an exotic woods lumber yard has opened and many varieties are now available. I think teak or maybe ironwood would look very nice.
/ Wood selection for outdoor chairs #11
Built mine with Ipe. But very heavy and a difficult wood to work. Teak is best but very expensive. Same for mahogany . I vote for cypress and next choice, western red cedar .
/ Wood selection for outdoor chairs #12
Solid PVC Plastic and never touch them again. Going on 3 years now, very hostile environment (salt, wind) and no problems.
/ Wood selection for outdoor chairs #13
ddbackhoe.
Thanks. That will be the back for a bench I'm putting together. It's a 2" slab of white pine. Locally, it is really tough to find a cedar that isn't full of nails, staples or fencing.
/ Wood selection for outdoor chairs #14
You could also consider mixing wood species. Ipe is very rot resistant, but heavy and difficult to work with. How about that for the legs (ground contact). You could then use Cedar for the seat and back to lighten the chair up a bit. With the right mix of woods it might also provide for a nice visual appearance.
Ipe reacts poorly with iron so you need to use stainless fasteners.
/ Wood selection for outdoor chairs #15
Lots of good woods to use, but the only one on your list is the red cedar. Some have mentioned white oak. It has limited rot resistance in my experience. Red oak has none, and WO is better, but still not really an exterior wood. A hierarchy:
Teak
Ipe
Cypress (old growth is much better than new growth but impossible to find unless reclaimed)
Spanish Cedar
Red Cedar
Treated wood
There are others I am sure. Local availability varies. I have never seen cypress lumber locally, for example.
The lighter woods have their pros/cons: Easier to move the chair, but then they are easier to blow around in a storm. Pick yer poison. You can't beat Teak, but it is expensive and hard to work with. Plus heavy, if that matters to you. There is a company around here that makes outdoor furniture from recycled milk bottles (HDPE) and other additives, which are really nice and durable, but heavy ( again - depends what you think about that...)
My $0.02
