The WICKED Root & Debris GRAPPLE!!!!!!!
   / The WICKED Root & Debris GRAPPLE!!!!!!!
Well I'm stoked!!! My WR Long arrived today and my wicked grapple has shipped!!!!
The countdown is on! We look forward to hearing(and seeing) more!
Travis
   / The WICKED Root & Debris GRAPPLE!!!!!!! #622
I like the idea of having independent action of each jaw, that is the only thing I wish by BoDozer Grapple had.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #623
How does independent action help? Indeed, how do two jaws help (compared to a single half width jaw)?
   / The WICKED Root & Debris GRAPPLE!!!!!!! #624
This is why the 72" is such a good fit for larger tractors. It wouldve been difficult carrying the stump mainly but it was nice having the width for the long logs also. The stump was enough to get my 9500lb+ tractor light in the rear. The BB is only about 1k and I have loaded rears.
Brett
Agree, Don't skimp on rugged construction if your tractor can handle the weight.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #625
1) even the lightest duty grapple is made of far sturdier material than even a heavy duty standard bucket. Nobody "breaks" grapples trying to lift heavy loads.
2) you can use a one ton grapple if you want but your net lift capacity will always be lower with a larger grapple than with smaller.
3) the risk with carrying a very large log or tree is not the weight but rather the twisting force if you don't grapple at midpoint or if you move too quickly or hit an obstruction on one side while moving. The twisting force is as likely to damage the FEL as the grapple and frankly if one has to give I'd rather it be the grapple. Way easier to repair or replace.
Our Wicked Grapples range from 255 pounds up to a whopping 435 pounds currently. :D
Customers can go wide if that's their preference and still maintain much of their lift capacity.
Some of your replies have indeed made me more open minded concerning grapple width.
Travis
   / The WICKED Root & Debris GRAPPLE!!!!!!! #627
The countdown is on! We look forward to hearing(and seeing) more! Travis
I just got the call that it's at the dock!!!!!
Now I'm going to go on short sleep to hopefully grab it in the morning! I'm excited as I can't wait to out her to work!
I still need to attach the third function you sent. I've just been so busy cleaning up the 3540 to get it up for sale.
This grapple should be a game changer for me.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #628
Remember, this is the internet: nothing exists without pictures. :D
Enjoy your new grapple!
   / The WICKED Root & Debris GRAPPLE!!!!!!! #629
I have become beset with grapple envy.
I've tried to follow the "how big" and read some like it small, others like it big.
(How did he get a 9500lb tractor? tractordata.com lists it at 5500 lbs, do loaded tires, cab and FEL add 4k lbs?)
I just weighted my tractor with the box blade and gravel. Truck and trailer are 15980. Truck, trailer and tractor were 27000
I'm surprised it's that heavy
11k lbs
Brett
205196 (A52706)
205196 (A52706)
UNUSED FUTRE FL-ESC220 ELECTRIC STONE CRUSHER (A52706)
UNUSED FUTRE...
2009 International 4300 Truck, VIN # 1HTMMAAN79H163641 (A57453)
2009 International...
2013 MACK CHU613 (A58214)
2013 MACK CHU613...
Utility Tilt Trailer (A55787)
Utility Tilt...
2003 Big Tex 10PI...
