newbury
Super Star Member
- Joined
- Jan 8, 2009
- Messages
- 14,881
- Location
- From Vt, in Va, retiring to MS
- Tractor
- Kubota's - B7610, M4700
From a long thread, far far away
Is there some reasoning behind this? I'm just trying to understand why.
<snip>
NPT fitting are not designed to be used over and over. You crush the threads every time you tighten.
Try Loctite 542 red.
J_J - Is there any "rule of thumb" on how many times to reuse versus replace?
<snip>
Just reuse the NPT fitting until it leaks to much.
Looking at discounthydraulichose.com and a couple of other sites all the QD's or QC's seem to come in NPTF.Yep, JIC are alot better. But if your hoses are NPT already, you can get some NPTM fittings to put between the hose and whatever. They are like a JIC in that the seal requires no sealant, and seals against a flare. Just on the inside instead of outside.
