new ck 2510
/ new ck 2510 #1
scrimshaw
florence, wi
kioti ck2510
After reading , lurking and not buying a tractor , I finally pulled the trigger on a ck2510 Hst, with front end loader. ( 14400$) if your curios. Looked at lots of Kubotas , but after reading all the posts here i am expecting to be very happy with my purchase.
I also added a box blade , rear remotes , and filled the tires. I am nit getting it delivered for a couple of weeks so there will be more to tell later. I am mostly going to use it for food plots, fire wood, moving dirt, trails and goofing around. I got sick of a wheel barrow and a shovel. Thanks everybody on this forum for all the helpful posts!:)
/ new ck 2510 #3
Have fun, but be safe.
/ new ck 2510 #4
Congratulations on the new tractor. Make sure you post pics when you get it :thumbsup:
/ new ck 2510 #5
Congrats on the new machine. I bought the same one back in December for about all the same tasks. It's been an awesome tractor and i just hit 44 hours yesterday with no problems so far. I didn't get any remotes installed, but I'm leaning more towards getting a 3rd function or diverter for it on the loader. I only wish it had ssqa on the loader. I am thinking about getting the tires loaded as well.
/ new ck 2510
Will post some pictures when I get it going. I have lots of cleaning up to do after getting a new driveway last fall. I also was hoping for a ssqa, I think the dealer mentioned that could be welded on after if needed. I also may add a mid pto and snowblower in the future if needed.
/ new ck 2510 #7
I bought a new ck 2510 also. I sold my beloved ck20 (1600 hours) along with the rear snowblower. I kept the backhoe from the ck20 and will use it aboard the 2510. I had nearly 1700 hours on the ck20 and I hope this ck2510 is as trustworthy. So far so good. I am really having a great time with the dealer installed cab onboard the ck 2510. The dealer, Michigan Iron di a fine job setting up this ck2510 just as he did 7 years ago when I bought the ck20.
rimshot
/ new ck 2510 #8
Enjoy, Same machine I got last september. No problems so far. Moved alot of snow this year!
/ new ck 2510 #9
I bought a CK2510 back in November.I had a pin hole in the curl cylinder, Dealer got me a new one.My check engine light flashes a code but not all the time on start up.When it does the engine stumbles a little when throttle is moved up. I have 27 hrs on mine.Hope you enjoy it!
/ new ck 2510 #10
I just bought a CK2510HST today with FEL, BH and box blade. Supposed to be delivered next Wednesday. I researched for months and this seemed to be the best bang for the buck. The LS XJ2025 was close but the Kioti had 600 pounds more weight and more comfortable. Really looking forward to putting it to work.
Robert
/ new ck 2510 #11
Robert
My reason for selecting the MAX28 over a 2510 was i wanted a gear, but not the 3X2 of the 2510. Had it had a 8x8 shuttle, the Kioti would be in my shed most likely. I like the near 400 Lbs more iron in the 2510 and the 4 link loader curl linkage.
Hydraulic Breaker Excavator Attachment (A61572)
Hydraulic Breaker...
2023 John Deere XUV 825M S4 (A60462)
2023 John Deere...
86 (A63290)
86 (A63290)
E-Z TRAIL 3400 SEED TENDER (A63291)
E-Z TRAIL 3400...
2014 Generac QT02724 Anax Generator (A61572)
2014 Generac...
2021 Walker Neuson G25 Quiet Power 20kW Towable Generator (A61572)
2021 Walker Neuson...
