Help With JD 318 please
/ Help With JD 318 please #1
wdenton
michigan
jd 318 , ford 860
Hello
I inherited a JD 318 with the onan engine removed and a Honda engine installed.
So technically I own a HonDeere
Yesterday I was mowing the lawn and leaned over to duck out of the way of a branch and the tractor stalled and will not start
If I turn the key nothing happens (no sounds no clicking and no dash lights)
I am guessing it is a safety switch but not sure if I am correct and I am not sure how to test them.
Also maybe a fuse but I cannot find where the fuses are.
Any help would be appreciated on helping me fix this would be great. I have half a lawn mowed and half a jungle starting.
/ Help With JD 318 please #2
The JD 318 is a great little tractor.
Who knows what they did when they changed the engine ? They may have even moved the fuse block.
It is probably a seat safety switch. I'd bounce up & down on the seat and maybe even hit it a few times where you sit. I doubt it is a fuse.
Thanks for the reply
Where was the fuse box originally.
Also for the seat switch is there a way to Temp disable it to see if it is the problem.
I want the switch on since I have kids that also mow the lawn.
Or if they are not expensive should I just buy a seat switch and replace? (I am not sure how much they are)
/ Help With JD 318 please #4
For testing purposes you can unplug the seat switch and jump across the wires with a jumper wire. Also make sure that you have disengaged the pto switch. I have seen that a couple times were people say there tractor won't run, and the pto switch is still engaged.
/ Help With JD 318 please #5
That's what I was thinking PTO is still "ON" not allowing it to start.
I will check them both.
Will either of these cause the lights and the dash lights to not come on also?
Not sure how to jumper the connector to the seat switch. the connector has an end that has a post like a trailer light connector like these Bing Images
So do I stick the wire inside the post or wrap around the post and then stick the wire in the hole also?
Sorry for the dumb questions but I am definitely a little green in this area.
Also how do I disengage the PTO besides flipping the switch down?
I really appreciate the help you guys are giving me.
After some research I found the part number but I am still not clear on how to jumper this
the seat switch part number is AM36850
Also I am not sure how to disengage the PTO
/ Help With JD 318 please #8
I suspect there are two wires to the safety swithch, being that it is an older tractor. If so, just make up a short u-shaped wire that will plug into the connector and "jump" or connect one wire to the other.
/ Help With JD 318 please #9
If lights are not coming on -- it may be that you are not getting power from the battery to the ignition switch. It has been 11 years since I had my 318 so I don't remember all the fine details of the wiring. There is sometimes a fuse right at the connections to the battery. Follow those wires to the fuse block.
Is it possible that there is a fuse at the battery terminal ?
/ Help With JD 318 please #10
With a 318, some age, and a different engine from someone else. I would say it's a main fuse, battery or switch problem. It would be the ignition switch, starter solenoid or the battery cables themselves. They used to have 2 or 3 fuses. Two between the battery and the backside of the dash and one under the battery tray. To get to that one the battery and tray has to be removed, unless it has the removable panel on the right sode. If it has the panel it comes off with one bolt and the other side just slides behind the metal.
Seat switches usually don't kill everything. So when the key is turned on the dash lights should come one it just wouldn't crank I believe.
Thank you for the information and you are correct on the fuse.
I will give you a quick update on what I have found
The 2 am fuse was blow so I replaced and it still would not start so I did some digging and also found a 20 amp fuse that is tied to the key switch and that was blown
I replaced it and the tractor runs (yah)
but when I engage the blade (pto ?) switch the 20 amp fuse blows almost instantly. The tractor drives and runs fine it the blade is not engaged
I am thinking the switch is bad but I have not figured out how to meter it or check continuity on it.
The switch looks like a sten with 5 post and all 5 post seem to be used.
so one connector has 2 wires and the other connector has 3 wires
they look like this
A new switch is around 30 bucks so I would like to make sure this one is bad first and that it is not a wire that is ground out when I engaged the switch
Any help would be greatly appreciated.
the format of the swtiches didn't come out
lets try again
/ Help With JD 318 please #13
Never attached a file before, but here goes.
View attachment 318 Tm1590 schematics.pdf
you may have to check the wiring of the pto switch.
also the pto coil may be shorted, check resistance to make sure coil is not shorted and blowing fuse.
find the full manual and download.
Sorry the link is not working.
If you like you can email it to me at wdenton07@gmail.com
I appreciate all the help I can get in fixing this.
When you say the PTO switch are you talking about the one I flip to turn on the mower deck that is currently blowing the fuses?
Or is there another switch I need to look at also?
/ Help With JD 318 please #16
If fuse blows when you engage the switch for the mower PTO clutch-- there may be some of the wiring insulation that has worn or rubbed and is touching metal (grounding). Look closely at all the wires you can see and check if they are grounding out on something.
/ Help With JD 318 please #17
And OR a clutch went grounded (short circuited). There are various relays witch will show up in that schematic. bjr
/ Help With JD 318 please #18
On the pto clutch that is bolted to the front of the motor. Pull the grille and side panels off and find the 2 wires coming out of the clutch up front and trace them back to the switch and make sure they aren't worn or bare like the other person mentioned. One may just go to the frame for a ground and the other should go to the switch. Check the ohms and then switch the switch on after unplugging the connector at the pto. If the fuse still blows when it's unplugged it's something before there or the switch it's self. I can't say I have ever seen a switch go bad and blow a fuse on a 318
/ Help With JD 318 please #19
Also, Many times I have seen where the plug that plugs onto the back of ignition switch get hot, melt and distort, sometimes even fusing itself right onto the ignition switch. This has happened to, my grandfather's, My Fathers, and my own 318 (also seen it on 300 series tractors at swap meets). Each time caused them to have a no power situation. I know the power for the front PTO runs through that switch as well..What I did to fix all of ours was to take insulated female connectors, crimp them onto the wires and reconnect them to a new ignition switch noting which terminal they came off of originally and making sure they land back on the correct terminal. Havent had a problem since.
Maybe something in there is touching something it shouldnt be...
Also if your tractor takes the round glass type inline fuses where you had said you found the 2amp and 20amp fuse, I recommend swapping them out to the square push in type fuses, the round glass ones are also a known hot spot prone to melting on these tractors.
Thanks for all the suggestions.
I got her up and running now
I took of the electric clutch and metered it out and it was getting .02 so the coil was shorted.
I ordered a new clutch and put it in and it runs like a champ now.
2022 CATERPILLAR 259D3 SKID STEER (A65056)
2022 CATERPILLAR...
MAHINDRA 2538 TRACTOR (A65057)
MAHINDRA 2538...
2019 CATERPILLER 249D SKID STEER (A65056)
2019 CATERPILLER...
2025 JMR Stump Bucket Mini Skid Steer Attachment (A66734)
2025 JMR Stump...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
2023 CRUISER RV SHADOW CRUISER (A67714)
2023 CRUISER RV...
