JD 450C Steering issue
/ JD 450C Steering issue #1
klmahnke
Delta Jct, AK
1978 John Deere 450C
Good morning all, new to this forum. I have a JD 450C with 3600+ hours, 1978 model. This is a new machine to me and the first machine I have owned. The other day while using the machine (machine worked as intended) the right stick for steering became harder and harder to move machine in intended direction until it finally stopped machine completely when pulling back. A few weeks ago I broke a hydraulic line on the backhoe, fixed it and filled reviser with fluid. I am wondering if this may have anything to do with the issue at hand. Looking under the seat I find two hydraulic valves which I am assuming are the brake adjusters? I am also assuming that pulling back on the track steering applies pressure to the brakes to turn? (Remember, I am new to tractors) Can someone give me some help in trouble shooting this issue? The machine drives straight right now but, when pulling back on the right stick, machine stops. When you let go of the stick it holds fast for a few seconds then releases and will travel forward again. Also, are there any fluid filters to change on this machine? I do not have a service manual for this machine! Man are they expensive! Any one have one for sale or know where I can get one? PDF version is fine.
Thanks in advance, Kaelin
/ JD 450C Steering issue #2
You're correct in that steering clutches on 450C are hydraulic. I would guess faulty control valve, low pressure or worn clutch discs.
Thank you for the reply and the diagrams. Here is what I can tell you. Referring the the second diagram. 1) how do you remove the valves and do you by chance have a part number. 2) right valve when line is removed from top will shoot fluid to the top of the cab with engine running, with valve open it stops. 3) left valve when line is removed from the top only shoots fluid about 18 inches high, with valve open it stops. Which valve is operating properly?
Again, thanks in advance for any help, Kaelin
/ JD 450C Steering issue #4
IMHO right valve is operating correctly BUT my JD industrial equipment knowledge is very limited as I was employed yrs back by an "ag only" JD dealership plus I have no access to a 450C tech manual.
Thank you, Tx Jim. If anyone else out there has a manual and could give me a part number and tell me if the valve can be changed from the top or if I need to remove the top plate to change it, I would appreciate it.
Kaelin
/ JD 450C Steering issue #6
youv'e probably over adjusted the brake by too
much jerking on the lever common problem if i remember my thousands of hrs on 450's. look up how to back off the brakes and quit jerking the levers pull them .you will find a large threaded plug with a 1/2drive hole over the adjuster on the top face of each final don't remember the procedure to adj [CRS]
Greg
/ JD 450C Steering issue #7
If spool valve requires replacement then housing will also need replaced as they come in a matched set.
Ordered and replaced spool valve. Pretty straight forward, disconnect the linkage and pull out valve. Same problem exists though. Now, I am pretty sure that the problem is still related to pressure but I am not sure where to go from here. I changed the filter for the hydraulic fluid (pretty dirty) so I am leaning towards a fouled line somewhere. What confuses me is that I have high pressure to one valve and low pressure to the other. Since they both take fluid from the same place it doesn't make since that this would be the case unless a valve was bad. I suppose it could be bad clutches but right up to the time it quit steering there was no issue, no hesitation, no jerking, nothing. Does anyone have the procedure to adjust the brakes?
/ JD 450C Steering issue #9
You have an open center hyd system.
Hydraulic System
Pump type Open Center
Relief Valve Pressure 2250 psi
The hyd system is open center, and the pump fluid flows through all valves to tank.
Can you install a pressure gauge in the first valve In port and check the pressure.
It should be low with all valves in neutral.
Don't have a pressure gauge but I replace the spool valves. Today I adjusted the brakes looking at the simple stuff first. Then, reading on another forum one gave instructions to test the drive clutches by pushing up against something stopping the tractor. Giving it throttle, only the right track turns. If this is the case it tells me that the left drive clutch either needs to be adjusted or replace. My question then is; does my left drive clutch need to be replaced? Is there a way without tearing half the machine apart to adjust the clutch pack? Now for the zinger. I am rural Alaska where the closest mechanic is hundreds of miles away. Besides any travel time hourly rate is $160 to $200. And being the left track doesn't drive, I can't get it loaded onto the trailer to move it from my property.
/ JD 450C Steering issue #11
If the right track works ok, you can drive it onto a low bed trailer - very carefully. I ran my 69 JD$%) with only one working clutch for a few years in the winter on snow clearing duties, before I eventually got around to doing both clutches (dry type). To correct where you would use the left clutch, go into reverse and use the other clutch - that should straighten you out ok - it worked for me.
Good luck with your trouble shooting and repairs.
Check out this JD website - you might just get some help there.
JDcrawlers Messageboard :: Index
Thank you for the reply. I have a tilt deck trailer and no level higher ground to drive the tractor straight on. May have to build a ramp. I have requested a quote from the John Deere dealer in Fairbanks for the repairs and may have to build that ramp to transport it. Wee shall see. If anyone else could answer my question; is it possible to adjust the clutch without tearing the machine halfway apart?
Thanks,
Kaelin
/ JD 450C Steering issue #13
There should be a test port to check clutch pressure. I will suggest you get a JD tech manual. phone # 866-213-3373 John Deere Bookstore
/ JD 450C Steering issue #14
Thanks,
Kaelin
Not sure if you've looked here JDcrawlers Messageboard :: View topic - 450C steering clutches. How long do they last?
"On your dozer you will notice a small triangle shaped cast plate on the drive casts both sides just above the tracks take the bolts out and get someone else to pull that side leaver .Here is where you set it .Set the clutch to open just before break enguages .Only if break bands were set up wrong will they need to be replaced and this could occur at any time .If the break sets it self to high then you have a lose older system and you can back the break of at the setting area "
Thank you for the information, I will try and get to it in the next few days. I will post back my results.
Kaelin
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A65054)
(INOP) 2013 MACK...
SDlanch SDLGC80 (A60462)
SDlanch SDLGC80...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
429872 (A61166)
429872 (A61166)
ATTENTION PLEASE READ (A64127)
ATTENTION PLEASE...
2016 JCB 507-42 (A64126)
2016 JCB 507-42...
