Gooseneck or bumper pull?
/ Gooseneck or bumper pull? #1
C4Ranch
Eastland Co, Texas
Kubota L5240 HSTC
My truck is rated at 13k conventional towing and 14k GN. If I go GN, I gain 1k lbs towing but the trailer will likely be 500 lbs heavier so only gaining 500 lbs towing.
GN trailer will cost abt $500 more plus equiping my truck with hitch will be abt $400.
Bumper pull gains me bed space but a may lose tongue weight but I do already have a weight distributing hitch but find them yet another step when loading.
Truck is a Chevy 2500 6L.
Any other advantages to a GN? What would you do?
Also, any advantage in a 2 1/2" receiver vs a 2"? Mine is 2 1/2" but I've seen 2" that go up to 16k lbs so why would I want a 2 1/2?
/ Gooseneck or bumper pull? #3
The towing limit is your Gross combined vehicle weight rating. What loads are you going to use the trailer for. Small loads ... a BP is doable. When you're moving large, heavy loads, the GN is the clear winner.
The biggest advantage of a GN is the stability. A bumper pull trailer has a 4 foot lever to move the truck around while towing. Also, a GN may be jack-knifed.
I pull a 35 foot horse trailer & a 24 foot flat bed ... Both GN.
/ Gooseneck or bumper pull? #4
The goose neck places more weight on the front wheels of the truck. I have both. and the goose neck is much more maneuverable and better handling. You could put a bed on top of the gooseneck part. I like my bumper pull stock trailer. because I can also place a stock rack on the Pk bed. In in the process of converting my bumper pull trailers to pintle hitches. and would like to convert my tilt top flat bed to gooseneck.
/ Gooseneck or bumper pull? #5
How much weight are you wanting to pull? That would be the deciding factor for me.
Yes, GN's seem much more stable.
As far as maneuvering, I wouldnt say a GN is "more" maneuverable. But its a different kind of maneuverable. Yes, you can jacknife them and get them into and out of some tight areas. But they also dont follow the truck well at all. They cut corners very short. You need a WIDE approach to your driveway, or turning in you will always be running the inside tires off the drive. Same with backing in. To keep the trailer on a narrow drive backing in, throws your front tires in the ditch across the road. A BP trailer is alot better pulling in and backing in a driveway that is narrower
/ Gooseneck or bumper pull? #6
i'm with you here, there are places i can take a 28ft enclosed trailer that i can't take my 27ft GN because i can't make a turn without putting one sides of tires into the ditch
/ Gooseneck or bumper pull? #7
You can turn a GN around where a BP would wimper at. The gn reacts to a turn slowly at first but the angle of turn caN be much sharper. I will only partially agree about the narrow driveway comment. Swing into the other lane a bit or have a truck that turns sharper and it's not a big deal. For a 2500 gas motor I think you are at the max with a 14k gn. The trailer will haul alot more than the Truck will handle if you don't get a cheaply made trailer. What is your intended loads op?
/ Gooseneck or bumper pull? #8
I have switched virtually every trailer I own to goosenck. I own four gooseneck trailers and I love them. They pull so much better than a bumper pull. I have pulled 14k bumper pull trailers before and they work but personally if I was getting anything larger than a single axle trailer I would get a gooseneck.
/ Gooseneck or bumper pull? #9
I've had both a 28 ft BP and a 28 ft GN. If I ever got another trailer that size, ,or larger it would be BP.
The GN backs up like crap....really really hard to do as the pivot point is over the axle.
My BP trailer was so well balanced and followed the truck so well that I could very easily forget it was behind me.
You still get to use your truck body to carry stuff as well.
I vote BP all the way.
/ Gooseneck or bumper pull? #10
Have you considered that you may have a need for both?
Looking to upgrade from this. Not safe at all and should t have done it. Light weight car hauler.
I could max out 2 7k axles depending on how many implements I carry.
I'm looking at 24'.
/ Gooseneck or bumper pull? #12
I've had both a 28 ft BP and a 28 ft GN. If I ever got another trailer that size, ,or larger it would be BP. The GN backs up like crap....really really hard to do as the pivot point is over the axle. My BP trailer was so well balanced and followed the truck so well that I could very easily forget it was behind me. You still get to use your truck body to carry stuff as well. I vote BP all the way.
I find that BP and gooseneck back easy. Backing a trailer takes practice. For anything over 10k you couldn't give me a BP. Length of the trailer makes little difference I think. I have a 24' enclosed BP and a 24' flatbed 14k the BP does fine at less then 10k but I much prefer a gooseneck for stability and better handling of the weight if over 10K.
/ Gooseneck or bumper pull? #13
And do the same thing with the same length BP and you can do it in a narrower area.
Out in the sticks where i live, roads arent always very wide, neither are peoples driveways. I park on the road alot with the GN when doing jobs that I would back in or pull in if still using my BP
/ Gooseneck or bumper pull? #14
When pulling any trailer you have to do whatever is necessary to get properly set up to make turns into tight places. if a driveway is iffy I wont try to turn in one on the blind side. I will go down the road and turn around hit it from the opposite direction. I drove a long Peterbuilt with a 48 ft end dump and most places aren't build for that combo. After driving that rig a half million miles. a Small truck and gooseneck is nothing.
/ Gooseneck or bumper pull? #15
I don't have a stoplight within 10 miles of me. The roads make no difference to me. If it's a two lane road, I'll stop and make someone go around me or make them pull off for me to get by. My international will out turn any pickup except a regular cab short bed truck I think. You still couldn't give me a BP for over 10k though. The more you practice backing up instead of saying it can't be done the more places it will fit.
/ Gooseneck or bumper pull? #16
I think you have vastly underestimated the extra weight the GN will weigh.
from the PJ website.
a 24' bumper pull 6" channel 14K equipment trailer curb weight =3400lbs
a 22' "classic" GN 14K GN weighs 4720.
a 25' is 5100lbs
Thats 1300lbs more for a GN with the same dual 7K axles under it.
my personal .02 is always for bumper pull.
/ Gooseneck or bumper pull? #17
I will add some more. From 2008 to 2014 I had three bumper pull 14k trailers. All three weighed over 10k pounds and we towed them all across the U.S. Made trips from Texas to Michigan, Wyoming, Arizona, etc. probably a combined 100k miles on three of them. At the time our trucks (three f-250's) had stuff mounted in the beds that prohibited goosenecks. They work and will get the job done but I hated pulling them.
You have to be really careful loading them or they will sway badly if not balanced correctly. Too light in the front and look out. At the same time you have to be careful not to put too much weight on the hitch as it is at the very back of the truck and will make the front end light which is also unsafe. Most bumper pull hitches are not rated over 1000 lbs tongue weight and it is easy to go over that on a 14k trailer.
Since we changed our setup and went to goosenecks pulling the trailers is a dream. They don't road walk and are much more forgiving on how you load them. Just this past week I loaded my 16' dump trailer with about 12k pounds of dirt all the way at the back. If you put it too far forward the lift struggles so loading the back makes it easier to dump. Anyway I quite possibly had a negative tongue weight and I pulled it about five miles and it didn't whip around at all. I don't recommend loading a trailer this way but the point is they are much more forgiving.
I don't find them hard to back at all. They are different to back than a bumper pull but not hard once you get used to them. Maybe you can't back them in as tight of a spot as a bumper pull but it has never been an issue for me. They make all different kinds of trailers and different people like different ones. I have owned most of them over the years probably over 25 trailers in my life and I have found gooseneck to be superior.
It is kind of funny as I write this I am considering purchasing a Belshe pintle hitch trailer for my dump truck to be able to pull my backhoe. I guess you could call that a bumper pull but it is in a whole different class with a 20k rating and is specifically built for a backhoe.
/ Gooseneck or bumper pull? #18
This is an interesting thread. I have always had BP trailers, but looking at having a 20' stock trailer made and was going to go with GN. My reasoning was that everyone I see around here is and there must be a reason... :confused3: Everyone I talk to says GN's are easier to back and with my 4 door/8' bed F-250 being close to 20' having a 20' trailer puts 44' on the road. Presently I own a 6x10 utility, 7x18 FB (for hauling hay & tractor), a 6x? kayak hauler (18' kayaks), 7x24 camping and they are all BPs in which I have never had a problem backing anywhere. I also have a shell on my truck that I would have to lose if I go GN which would be okay if I had to. Now I am wondering if I want to stick with BP? Was also looking at buying a 25' transport which was going to be GN as well. Now I m really confused
/ Gooseneck or bumper pull? #19
I have only owned or hauled BP trailers, because they've been deals too good to pass up. I have messed the weight distribution up on the 18' dovetail, and got lucky to get out intact. The nice thing about GN is that they always are planting a share of the weight between the truck axles. In application they should be much more forgiving for varied loads and load configurations. I don't know that you can load a GN to lever up the rear truck axle the same way a BP can and start getting driven by the load (?).
If you're buying anyway, and keeping the car hauler, my .02 would be to listen to whatever got you thinking GN, and give yourself a different option. Heavy loads and bad roads can create some pretty dynamic weight moments when the load seriously outweighs the tow vehicle, which I'm guessing yours does.
I still shudder when I recall seeing the tractor darting in and out of each side of the rear view mirror after hitting a huge pothole on a steep sweeping corner. I'm lucky I live in the sticks, no one was on the road, and a friend had described his Dad's crash when the same thing happened some time earlier. I punched it, and was able to get enough pull to tug the tongue back down. The first instinct was to go for the truck brakes (didn't have one set up for the trailer--then!), which would have been a quick wreck. Very fortunate to get the education without incident.
2014 VOLVO A40G WATER TRUCK (A65053)
2014 VOLVO A40G...
(INOP)1989 NISSAN D21 EXTENDED CAB TRUCK (A64280)
(INOP)1989 NISSAN...
NEW Wolverine DB-15-84W Snow Blade (A62679)
NEW Wolverine...
2018 LIEBHERR A900C LITRONIC WHEELED EXCAVATOR (A63276)
2018 LIEBHERR...
New/Unused Wolverine Mini Combination Bucket (A65583)
New/Unused...
ATS ATS-PC90 Heavy Duty Plate Compactor (A62679)
ATS ATS-PC90 Heavy...
