Oil & Fuel Diesel Fuel injection Pump Problems
/ Diesel Fuel injection Pump Problems #1
rculler3
Boston
Nortrac/NT-254
My Nortrac NT-254 Chinese made tractor has fuel coming out of the injection pump, but when I open the lines to bleed them, nothing comes out. Is the injection pump bad???
/ Diesel Fuel injection Pump Problems #2
No fuel will come out of the hard lines unless the engine is running, but you may get some by operating the lift pump manually.
If your injection pump sump is filling with fuel that means that one or more barrel and plunger assemblies have gone bad. This premature failure is usually caused by using dirty fuel combined with poor maintenance practices, and/or a persistent case of diesel bugs which can corrode fuel system components and completely destroy them. If you are confident there are no bugs, and the fuel is squeaky clean, you have an option open to you aside from replacing the injection pump assembly and that is to monitor the injection pump oil level carefully and change it more often as required.
/ Diesel Fuel injection Pump Problems #3
Where exactly is it leaking from? Does it leak all the time or only when started?
BOBCAT 435AG (A68134)
2012 INTERSTATE TRAILER 28 T/A GOOSENECK TRAILER (A67714)
2012 INTERSTATE...
2003 International 7400 T/A Dump Truck (A66736)
2003 International...
2004 NiftyLift TM50 HGE 50ft Towable Articulating Boom Lift (A66734)
2004 NiftyLift...
500 GAL WATER TANK (A68842)
500 GAL WATER TANK...
2019 SDLG L938F WHEEL LOADER (A65056)
2019 SDLG L938F...
