tiller sub compact
/ tiller sub compact #1
Maestro71
Ohio
Kubota bx2660 loader mmm back blade woods rotary cutter
will a tractor supply 48" tiller be a problem on a bx if it isnt the model designed for subcompact?
thank you
/ tiller sub compact #5
They both worked on my bx25 but are taller an 3pt hitch pins are higher then the subcompact models so it won't lift up as high for clearance. A real pain loading the machine onto a trailer with steep ramps. An also coming off or going up a steep hill Tiller always bottoms out on the ground. I had to switch to the sub compact country line 48" instead of the regular model cause of ground clearance.
2018 FORD F450 XL 4x4 CREWCAB 5K LB SERVICE CRANE (A62613)
2018 FORD F450 XL...
KUBOTA SVL97-2 SKID STEER (A65053)
KUBOTA SVL97-2...
2018 TAKEUCHI TB240 EXCAVATOR (A64279)
2018 TAKEUCHI...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
2021 Dodge Durango SUV (A61574)
2021 Dodge Durango...
Caterpillar M318 Excavator Service Manuals vol. 1 and vol. 2 (A63117)
Caterpillar M318...
