BX Front left axle seal leaky!
/ BX Front left axle seal leaky! #1
16valex
NY
bx23
Gents, please take a look at my leaks and tell what has to be done to resolve. TIA.
/ BX Front left axle seal leaky! #2
Your pivots seals are definitely bad. Not a hard job to replace them (<$50 ea.) yourself. If you have the workshop manual it has a good procedure. YouTube will have some vids if you don't have the WS manual.
Thanks, I try Utube.
/ BX Front left axle seal leaky! #7
i just did both mine..the pto cover is the pefect size to knock those rings on w/o denting them..cuz they sure are flimsy to dent
So **** Lame!!!!!!
How lame can I get? I went and replaced the pivot seal but, the WRONG SIDE!!!!!!!!
I need to think............Auto pilot mode is not as sharp as used to be.....F$$$$$$$&&&&&&K!!!!!!!!!
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2013 Ford F-350 4x4 Crew Cab Knapheide Service Truck (A61573)
2013 Ford F-350...
Lincoln Electric Shield-Arc SAE-400 - Radiator Missing - For Parts or Rebuild (A63689)
Lincoln Electric...
UNUSED WOLVERINE HYD STUMP GRINDER (A64281)
UNUSED WOLVERINE...
UNVERFERTH 14' FIELD CULTIVATOR (A63291)
UNVERFERTH 14'...
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
