Field fence pain
/ Field fence pain #1
joeu235
Little River, TX
John Deere 4020 / 6403 / 317 Ford 5600
My dad put up a bunch of net wire fence 10 years ago
to help keep coyotes out. Barbed wire on the bottom and two above above the net wire. Now the cows have pushed the top down between each post. We've started running a fourth wire right next to the top of the net and using hog clips to raise the net wire. Anything we did wrong in the first place or have a better idea?
/ Field fence pain #2
A strand of electric on top ought to solve the problem. They do have some pretty decent solar chargers, if it's not close to a power source.
/ Field fence pain #3
DJ54 is right. run a hot wire on the inside. I would prefer an offset that would be sticking in towards the pasture. You get that going and they will respect it. Then you will be able to fix your field fence at your leisure. Put a couple isolation switches on it at convenient locations and make sure your grounding rod(s) either go wayyy down or you have good access to keep the soil damp at the grounding point.
/ Field fence pain #4
As the others have said, electric fence wire should solve the problem. Cows and horses (and coyotes) will respect it. Hogs...not so much. They will test it every so often and will go right through it if it is off or grounded out. You might guess how I'd know that.
Anyway, if your fence run is not that long a low powered or solar charger should do the job. I prefer the longer stand-offs to keep the wire away from the fence to avoid grounding out. One stand off every three or four posts is enough.
The strand of hot wire can be strung at about four feet high or about a foot above most field fencing. That way the field fencing is protected as well as the strands of barb.
With hogs, the wire has to be a foot, or so, from ground level and Roundup used to keep the fence line clear. There are weed cutter chargers, but I've not had any experience with them.
As far as the wire sag goes, you can use a lighter wire to wrap around the top barb, then around the second barb, and finally on the field fence. That way the field fence gets two attachment points and is stronger. Install the light wire support midway between each post. But the way you are doing it with the extra wire and hog rings should work fine...still might get a bit of sagging however.
/ Field fence pain #5
even if you keep it tight as you can pull it and retension it it will sag...cows working it just makes it worse..save yerself the work...
/ Field fence pain #6
Just like the velociraptors from Jurassic Park.
/ Field fence pain
It would be easier to convince my dad to vote for Hillary Clinton than to string up electric fence everywhere. Thanks for the input though.
/ Field fence pain #8
Place a single strand of electric barb wire about 15-20 feet inside current fence. Post every 30-40 feet. Then when you have time repair or replace current fence. If post are good the replace wire. If post are bad then doze and start over. I have too much to do to fix fence everyday. I have become a big fan of 5 strands of barbed wire over a page wire fence. Just holds cattle longer. And can make any strand hot at any time. Easier to repair also.
/ Field fence pain #9
Cattle will not respect field fencing. Many strands of barbed wire or electric is the way to go. Or a combination of the two. Bruce
/ Field fence pain #10
What distance did you go between t-post?
/ Field fence pain #11
This is what I've been putting in lately. The old barb and woven wire was 40+ years old, so I guess you can say it did it's job, but boy I was glad to get it ripped out.
My new fence is 5 strands of electrified high tensile with 5 inch creosote line posts, and 6 inch posts in the double corners. They don't mess with it.
/ Field fence pain #12
Beautiful country and nice looking fence. ^^^^^^^^^^^
Depending on the charger, you many have to deal with the grass along the fenceline.
/ Field fence pain #13
It is amazing how fast cows (or other animals) learn to stay away from a one strand electrified fence. My dogs wont go near the white nylon type after getting into it one time only. It doesn't even have to be energized to keep them away. Cows will test it though, but on all but the most stubborn bull will stay behind one little strand, the more visible the better. My brother in law has miles of the stuff to section off his pasture to prevent overgrazing and it works fine. I put up some to keep my german shepherd pup from killing my chickens and it works fine for that too. The chickens know that they are safe on the back side of the fence and head there when the dogs are out.
Electric fence is much more humane to animals than getting cut with barbed wire. I have accidently touched it a few times and while it will jolt you, no damage is done. It is a heck of a lot cheaper also than net wire or 5 strands of barbed wire.
(4) 265/65R18 TIRES & 5 LUG RIMS IN BOXES (A64278)
(4) 265/65R18...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7866 Miles (A63689)
2019 Cadillac XTS...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
(9) STAMPED INTERNATIONAL FRONT WEIGHTS (A64278)
(9) STAMPED...
34in. Bucket with Teeth Excavator Attachment (A64194)
34in. Bucket with...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63689)
2023 Kubota L3560...
