Comparison Tractor decision dilemma
   / Tractor decision dilemma
The reason I don't want to mention brands is because then it becomes an unbiased opinion from some. With everything else being equal, i just wanted thoughts on am I being silly paying more for a tractor that doesn't have a wet clutch but is more fuel efficient and is better built.
Weights are equal, hydraulic flows are the same. Both are 3 Cyclinder turbo but one has an intercooler. service intervals are the same. etc etc.
I know the benefits of a wet clutch. But as i previously said I'm not doing loader work. A lot of tillage and towing is what I'm using the tractor for.
Wat size clutches roughly were many of the older tractors fitted with, Mtnview?
   / Tractor decision dilemma #12
I'm assuming that you are comparing NEW, on the dealership floor / yard, tractors, rather than used ones that you have considered.
My experience with the users on this forum is that the more details you provide (I know, goes against your intent), the better information you get. There are links here to brand specific tractors that you have probably already looked at. I know nothing about clutches (sorry) - all HST for me.
after everything - it just comes down to what colour you prefer :) (the ole Chevy, Dodge, Ford discussion of the tractor world)
happy hunting
   / Tractor decision dilemma #13
I definitely understand the desire to avoid a brand discussion.
Can you tell us how many hours a year you plan to run the tractor and how many years you plan to keep it? Are you the primary operator? Do you plan to sell or trade in a couple years? Are you looking a new or used? Is this your only tractor or a backup machine? These types of questions can help us provide better feedback.
From my perspective, if you are looking at a new machine and you are the primary operator, the clutch difference isn't really that big a deal. Both machines will do the job well. If money is not a concern, test drive both machines and buy the one that 'feels' the best. Every brand has different ideas on what comfortable feels like and one will probably seem better to you than the other. If money is a concern just buy the cheaper one, you won't be disappointed.
Good luck.
Good luck.
Thanks Mathias. I know myself I find it extremely hard to be unbiased when it comes to cars or tractors and I am pretty open minded.
It is is going to be one of 2 primary tractors where I'm the primary operator. Looking at a new tractor. I'll probably be doing 300 hours a year with it. Fuel economy is a big thing for me and having had a good run in the past with dry clutches (knock on wood) has me leaning towards the tractor with the dry clutch.
3 weeks ago the thought of purchasing the tractor with the dry clutch was a joke to me considering for the same money or less I could get tractor with a wet clutch.
   / Tractor decision dilemma #15
If I were buying a new tractor (larger with a gear tranny) today I would prefer a wet clutch. I prefer a wet clutch, a wet sleeved engine, planetary gears, mfwd and power shuttle or power shift transmission. What I may settle for may be different, at that point I would have to decide which things were more important in that scenario. Good luck with your decision.
   / Tractor decision dilemma #16
Are the transmission choices the same? What about radial vs bias tires? Any wheel weights or loaded tires? Hydraulic scv run about a grand per pair. Does one have telescopic draft links? Is one top link or bottom link sensing? WHT about emissions? Is either one a tier 4? Have you test driven either one to get a feel for the controls?
   / Tractor decision dilemma #17
If it was me I would buy the first tractor. Unless that is not the first tractor then I would buy the second tractor. But to not be biased I would add a third tractor. But, if I was doing general work as opposed to not so general work then I would get the second tractor with the wet clutch unless it was the first tractor that had a wet clutch then I would get that one unless the third one was actually the first and then I wouldn't worry about what this post doesn't say regardless of what I was buying since I have no idea what you are doing with the tractor.
That being said, I can't wait to see the pictures of the new purchase.
   / Tractor decision dilemma #18
Well, my most used loader tractor has a dry clutch and after more than a thousand hours of HARD loader use, it still works perfectly and has not needed any adjustment...
A clutch last according to how you use it!!
If you use it "like you are suppose to" use it, it will last a LONG time, if you are one of those guys that likes to slip the clutch all the time, then yes, a wet clutch will last a lot longer.
Choose a low enough gear that you don't need to slip the clutch and you won't have any clutch problems for a LONG LONG time!!
SR
   / Tractor decision dilemma #19
I understand the want and need for unbiased opinions, but most of us here give such opinions anyway. It is impossible for the OP to give every detail that may be pertinent. Often there are little things, or additional stats about the tractor that people know. There was a recent post in which the OP was comparing two tractors. As he had stated the model and brand, we were able to look up the tractor and pointed out several things about each tractor that the poster had overlooked and ultimately determined which tractor he bought. Also, biased opinions are easily recognized and ignored.
   / Tractor decision dilemma #20
Exactly. :thumbsup::thumbsup:
Atlas Copco XAS90JD Portable Air Compressor (A57453)
Atlas Copco...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A55315)
2023 Unverferth...
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
2011 Kubota KX080-3 Midi Excavator (A56857)
2011 Kubota...
White Metal Roof Panels (A55758)
White Metal Roof...
