deck belt sx3100 with ds60 deck
/ deck belt sx3100 with ds60 deck #1
greif
kaukauna,wi
Yanmar sx3100
Hi
does anyone know the size of the belt for the deck ds60 on the sx3100? mine broke and dealer does not have one so will take several days to get. Wondering if I can cross reference to a different belt.
thanks
/ deck belt sx3100 with ds60 deck #2
I do not know the answer but do you know why your belt broke? How many hours do you have on it?
Sent from my iPhone using TractorByNet
Only have 23 hrs on it, I did not take the deck off to look at it yet. Last week I ran over a fallen brach about 2" dia and it jammed under there and stopped the blades but the tractor kept running so I know I smoked the belt, must have weekened it in one spot?
I will pull it off in the morning to verify.
Dslanec, how much does the snow blade cost?
/ deck belt sx3100 with ds60 deck #5
I posted on the CC forum also.
Try this out: Its a Napa part number so it can be crossed referenced at any parts store. Let us know how you make out.
Product ImageLogo Image
Belt - Deck
Part Number: NBH 6817BR
Product Line: NAPA Belts & Hoses
/ deck belt sx3100 with ds60 deck #6
I don't have the factory one. I modified a poly truck plow. I had the factory blade when I had the sc2400 though. If I recall correctly the blade was just over a grand and I got the front mount from the dealer for free but it was just south of a grand also I think. My current blade is 7.5' and a bit to long but sometimes I just can't take a full blade width. I got a deal on the plow, next to free from a friend, so I have less than 500 total into current setup.
/ deck belt sx3100 with ds60 deck #8
Are you mounting on a front hitch or onto the loader arms? Please post some pictures of your setup when done.
I checked with local Napa and other automotive stores and no one had that size in stock so I ordered it. The old belt broke right were the pulley burnt it when I got the big branch stuck under it and stopped the mower but not the PTO. Took about 10 minutes to change, will go faster next time. Just need to look out better when mowing tall grass
/ deck belt sx3100 with ds60 deck #10
It is on the loader arms. My dealer welded a quick mount onto the plow for me. Now I can easily switch and put on the bucket if I need to move snow around. Here are a couple pics I found I already had. I wired it so I use the original hand held remote that came with the plow. If the plow was a foot shorter it would be perfect but I can't complain because the plow was basically free. Sent from my iPhone using TractorByNet
Did the delear build or buy the quick mount?
Can I have your dealer contact, or if you could find out were he gets them? My dealer s not been able to find one for our loader. If it's only $100 or so it don't pay for me to try and make the brackets myself
/ deck belt sx3100 with ds60 deck #14
It is genes power equipment in Coleman Michigan. Genespowerequipment.com
thanks, did he buy just the 2 brackets that go onto the loader mounts or is it a mount with brackets and cross pieces connecting them?
/ deck belt sx3100 with ds60 deck #16
My guess is just the 2 brackets and he welded them to make the whole bracket but I honestly do not know. I could take some pics of the mount if that would help you out?
I emailed him and he has them for $89 a pair of brackets. He has a local fan shop make them. I will have to call him tomorrow to order
Thanks for the help
Bobcat T66 (A60462)
Bobcat T66 (A60462)
KBH 25 TON TENDER (A61307)
KBH 25 TON TENDER...
2022 Blue Diamond Brush Cutter (A64126)
2022 Blue Diamond...
1998 Volvo VNL64T Sleeper Truck (A62679)
1998 Volvo VNL64T...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63688)
2019 Krause...
iDrive TDS-2010H...
