deck belt sx3100 with ds60 deck
   / deck belt sx3100 with ds60 deck #1
greif
kaukauna,wi
Yanmar sx3100
Hi
does anyone know the size of the belt for the deck ds60 on the sx3100? mine broke and dealer does not have one so will take several days to get. Wondering if I can cross reference to a different belt.
thanks
   / deck belt sx3100 with ds60 deck #2
I do not know the answer but do you know why your belt broke? How many hours do you have on it?
Sent from my iPhone using TractorByNet
Only have 23 hrs on it, I did not take the deck off to look at it yet. Last week I ran over a fallen brach about 2" dia and it jammed under there and stopped the blades but the tractor kept running so I know I smoked the belt, must have weekened it in one spot?
I will pull it off in the morning to verify.
Dslanec, how much does the snow blade cost?
   / deck belt sx3100 with ds60 deck #5
I posted on the CC forum also.
Try this out: Its a Napa part number so it can be crossed referenced at any parts store. Let us know how you make out.
Product ImageLogo Image
Belt - Deck
Part Number: NBH 6817BR
Product Line: NAPA Belts & Hoses
   / deck belt sx3100 with ds60 deck #6
I don't have the factory one. I modified a poly truck plow. I had the factory blade when I had the sc2400 though. If I recall correctly the blade was just over a grand and I got the front mount from the dealer for free but it was just south of a grand also I think. My current blade is 7.5' and a bit to long but sometimes I just can't take a full blade width. I got a deal on the plow, next to free from a friend, so I have less than 500 total into current setup.
   / deck belt sx3100 with ds60 deck #7
How did you make out with the belt?
   / deck belt sx3100 with ds60 deck #8
Are you mounting on a front hitch or onto the loader arms? Please post some pictures of your setup when done.
I checked with local Napa and other automotive stores and no one had that size in stock so I ordered it. The old belt broke right were the pulley burnt it when I got the big branch stuck under it and stopped the mower but not the PTO. Took about 10 minutes to change, will go faster next time. Just need to look out better when mowing tall grass
   / deck belt sx3100 with ds60 deck #10
It is on the loader arms. My dealer welded a quick mount onto the plow for me. Now I can easily switch and put on the bucket if I need to move snow around. Here are a couple pics I found I already had. I wired it so I use the original hand held remote that came with the plow. If the plow was a foot shorter it would be perfect but I can't complain because the plow was basically free. Sent from my iPhone using TractorByNet
2011 ORTEQ ENERGY SERVICES 40 MANIFOLD TRAILER (A52472)
2011 ORTEQ ENERGY...
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
2015 Caterpillar 410L 4x4 Extendahoe Backhoe Loader (A51691)
2015 Caterpillar...
2013 International WorkStar 7400 4x4 Altec DMA71 Insulated Digger Derrick Truck (A51692)
2013 International...
NEW  Ripper Shank (A53002)
NEW Ripper Shank...
MILLER BIG BLUE 500 PRO TOWABLE WELDER (A52472)
MILLER BIG BLUE...
