New Piranha Bar
/ New Piranha Bar #21
I have a bolt on replacement cutting edge. Can a piranha bar fit over it?
/ New Piranha Bar #22
Gixxergary,
I have the same tractor and bucket and was wondering if you could guide me on the length you selected for your Piranha tooth bar?
I measured the inside dimension and depending on where you measure, it is between 58 1/16" to 58 1/2" wide. I'm going to attach a picture to help explain...if you measure the vertical sides of the bucket it is exactly 58 1/2"......if you account for the thickness of the welded reinforcements where the vertical sides meets the horizontal bottom, it is 58 1/16". Hopefully the attached picture will help show what I'm explaining. Based on those funky welded reinforcement, what lenght did you order? I can do metal fabrication so, if I need to extend the reinforcement to make a solid mounting surface at 58 1/16" wide, that will not be a problem.
BTW...I had a BX25 with the Piranha tooth bar and it turned that maching into an animal!!! I've since upgraged to a B2650, sold my BX's Piranha tooth bar and NEED to have it back on my new bucket. This tooth bar is far too economical and it performs so awesome that it is hard not to have one on hand!!!!!
Thanks!
On both counts... I would contact Harry at BXpanded directly and make sure he fully understands your requirements. He is great to deal with.
/ New Piranha Bar #23
Actually did so & I agree...placed an order today.
/ New Piranha Bar #24
So what did he say about your situation? I will be ordering the same tractor/60" bucket, and would like to order/buy the PTB and have it when the tractor is delivered.
/ New Piranha Bar #25
He might have said that he has longer ears that can be attached that will get beyond the reinforcement. That's what he said to me. I received my 60" (58 1/8 ") PTB yesterday and installed it. We discussed the fact that I might need slightly longer bolts and he suggested that I go to TSC and pick up something if necessary. I was able to just barely get the bolts tightened using a c-clamp so I did in fact replace one of the bolts. I'll attach another picture of the PTB installed when it stops raining. As you can see my bucket is very similar.
/ New Piranha Bar #26
I provided both dimensions and a photo. When I received my PTB, the ears were welded to accomodate the smaller dimension. I asked before installing because it looked like the ears would need to substantially bend during installation and I was told that this is ok and normal for the install. Long story short, I installed using a clamp to help pre-bend the ears and all is working as it should. In the future, I may weld a piece of plate on the inside of the bucket where the PTB ear holes are so the ear / tabs do not need to bend as much and installation won't require the use of clamps. Here are a couple of photos of mine installed.
Also, I never thought about this until after I finished my install but, if you have the capability of welding thick steel, I might see if he will provide the tooth bar cut to lenght and the ear tabs un-welded. In my case, I would have preferred that for my install, as I could have welded the tabs in the perfect spot on the tooth bar and I wouldn't need to weld any plate spacers in the bucket (which is probablly overkill but that's the way I roll :thumbsup:)
Hands down...bar none....this PTB is by bar the best you can buy for your money and then some!!!!!!!!!!! Turned both my BX and now my B into a digging animal!!!!!!!!
/ New Piranha Bar #27
I agree.....great product. I put one on my little Yanmar a couple of years ago. I never take it off. Have cleared tons of blackberrys....small trees.....brush. Have used it for digging out the side of some hills. Works great. I had to special order mine.......I cut a 1x2 stick to fit inside my bucket.....took exact measurements......talked to the Piranha owner and they took it from there. Nice folks to deal with....great product.
/ New Piranha Bar #28
Hold two yardsticks together, slide apart till tight inside the bucket, then add the measurements.
(Be sure to hold them so the zero end of the one you are reading touches the bucket)
36 + second stick's number where they meet = inside width
Bruce
2018 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
2018 CATERPILLAR...
2016 Ford F-550 Flatbed Truck, VIN # 1FD0W5HT7GEC46417 (A65563)
2016 Ford F-550...
211298 (A62131)
211298 (A62131)
NEW HOLLAND TN75D TRACTOR (A64280)
NEW HOLLAND TN75D...
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
2005 Jeep Grand Cherokee SUV (A59231)
2005 Jeep Grand...
