Fiat 411 R starter motor
/ Fiat 411 R starter motor #1
NevilleY
Manjimup WA Australia
Fiat 411 R
Hi i have a Fiat 411 R series tractor, it has a 24 volt system, i went to start it as normal and smoke came out the starter motor ,the engine turned very slowly twice, i gave it a couple minutes and the same thing happened again.I removed the two 12 volt batterys ,tested for charge and they were a little down, so i charged them on a trickle charger,, put the batterys back in and hit the starter, same thing mentioned above happened,,,,,,,So i have two questions..First ,does this mean the starter motor is worn out or burnt out and 2nd question what is involved to convert the 24 volt system to a 12 volt system....i see on ebay starter motors for the tractor are around $650 or more new... (Australia)... thanks for any help or replys,,,,,,,,,
/ Fiat 411 R starter motor #2
could you possibly post picture of your starter also any numbers on it
2019 Cub Cadet Ultima ZT 1 50in Zero Turn Mower. (A64557)
2019 Cub Cadet...
ATS 60 Gallon 2 Stage Air Compressor (A62679)
ATS 60 Gallon 2...
1998 Mack DM690SX Chassis Truck  (A62679)
1998 Mack DM690SX...
(8) Used John Deere Hydraulic Cylinders (A65640)
(8) Used John...
New Holland 499 MoCo (A66408)
New Holland 499...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
