Max 28 backhoe question
/ Max 28 backhoe question #1
John32369
New London NC
Max 28
I recently purchased a backhoe for my Max 28, its the 26B model. I've noticed after I park it and curl the arm and the bucket up or if I take it off and leave it sitting on the stabilizers, that they leak down and I have a somewhat lower backhoe to put back on the tractor. Is this normal?
/ Max 28 backhoe question #2
yeah that's fairly normal over time. Mine would 'hold position' for maybe a day, and then I'd have to hook the remotes up and raise it back up. was never really a big deal but it is kinda funny.
/ Max 28 backhoe question #4
John 32369,
I concur with the input of the other posters. They are right on. If I were you I would go ahead and lower the stabilizers, etc. and release the pressure off of everything. I don't know if it hurts anything, but it can't be a bad thing either. I have the same BH and recently had a problem with my BH and its operation. As it turned out the positioner valve had blown its guts out. This left a jerky motion for the main boom (next to the tractor) on the BH. What I believe happened is that the snap ring was not installed correctly. With that, the guts blew out the bottom of the positioner that is attached to the valve body. The boom actually still 'works' but the action is jerky and doesn't have much down force. I suppose that it could happen to any of the positioners in the system. I mention this so anyone reading this might recognize this problem if it happens. It won't be obvious and there won't be fluid squirting on the ground. You will have to take the cover off of the valve body and inspect it. If you put your finger up and into the positioner you will feel a void as there is nothing there, only the spool.Others know more about this than me, but the spool is the solid piece that comes down through the positioner body when actuated by the the BH lever. Good luck.
/ Max 28 backhoe question #5
Blocking the backhoe frame with car jacks is a good idea to keep the unit up when unit is disconnected from tractor.
/ Max 28 backhoe question #6
john, do you know whats involved in replacing or repairing the positioner valve, i believe i have the same symtoms with my max 28 backhoe
/ Max 28 backhoe question #7
I made a cart so I can wheel it around the shop, it stayed in that position all winter.
/ Max 28 backhoe question #8
Also I put a ratchet strap across the stabilizers to keep them from leaking down. It worked great!
/ Max 28 backhoe question #9
As mentioned, leaking down slowly is normal and happens on all backhoes. It is not a defect, even on a brand new zero hour machine.
/ Max 28 backhoe question #10
On the tractor is should leak down but if its leaking down while disconnected id be checking for leaks... mainly at the hose connections... unless there is air in the system there is really no were for fluid to return to. Are you having to add Hyd fluid to the tractor often?
/ Max 28 backhoe question #11
It can go to the other side of the cylinder past the piston seals with no external leaks. Only so much of that can happen without a leak if gravity is pushing the rod back into the cylinder (like having the stabilizers holding up the backhoe with it disconnected) as the rod displaces some oil. As you mentioned, the oil must go somewhere. That will sometimes cause the quick connects to be nearly impossible to re-connect as those hoses end up dealing with the extra oil and take on some pressure.
/ Max 28 backhoe question #12
Correct... I had one do this not to long ago and rebuilt the cylinders.. had to keep the old parts and show the customer for him to believe me ha. He keeps it on blocks now adays
/ Max 28 backhoe question #13
But let's not cause folks to think that if it settles it needs rebuilt. Settling is normal and expected. Actual specs for allowable settling are alarmingly high. Meaning it can settle a bunch and be within specs of a new cylinder.
/ Max 28 backhoe question #14
j wilson,
I apologize for the delay in getting back to you, I've been on vacation. The short answer is no. I haven't attempted it yet as I am waiting for the cap/plug that covers the bottom of the positioner that keeps the dirt out. It (cap) didn't come with the positioner assembly for some reason. Curiously, Dave's Tractor told me that the company that makes these caps had never had a request for a cap/plug in the past six years. While I believe them, all I can say is that the snap ring that secures the guts of the positioner was not properly installed. If that snap ring comes loose, then the parts will fall/blow out of the positioner housing. The 'housing' reminds me of a spark plug wrench for a chainsaw minus the screw driver handle. Obviously, the cap would hit the dirt and be lost. I have the new positioner and it looks pretty straight forward replacing the original one albeit a bit awkward because it's in the back row. Maybe JJ or Dave's can chime in on this process. Good luck, wish I could have been more helpful.
/ Max 28 backhoe question #15
But in only a nights time? I let this one sit out disconnected after we rebuilt it for two days without any noticeable sag
/ Max 28 backhoe question #16
Let me give you the specs for a JD backhoe, because we can all agree that JD is quality and they have been doing this backhoe thing for a while. A model 47 stabilizer cylinder is allowed 0.3 inch (8mm) per minute as measured at the rod. Under that and JD will tell you that your backhoe is fine. 0.3" as measured at the rod is a bunch, a patient man could sit there and watch it settle at that rate. That is per minute, not per hour. The main boom cylinder is allowed 0.6"/minute on that same JD.
If it were my backhoe and was near the max specs, I'd not be happy. That seems like too much leak-by travel. But you can be sure that a loader that is left 2 feet in the air at night and is on the ground in the morning might well be in specs. Even if left over lunch it might be in specs. These piston rings are lubricated by oil, there needs to be a little bit of leakage to make them last.
But you alluded to an important point. Why do some loaders left in the air stay there for weeks? I haven't a clue....
I'm no hydraulic expert, there is my disclaimer.
/ Max 28 backhoe question #20
:thumbsup:
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
John Deere 2350 Tractor (A61166)
John Deere 2350...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
New/Unused 3 in 1 Bucket for Mini Skid Steer (A61166)
New/Unused 3 in 1...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
2015 Ford Explorer Multipurpose Vehicle (MPV), VIN # 1FM5K8B87FGB13389 (A61569)
2015 Ford Explorer...
