Adjusting Cut Off Pressure Of Air compressor??
/ Adjusting Cut Off Pressure Of Air compressor?? #11
A quick note to this thread for any others that may have a problem with their pressure switch: I was just amazed to find that one can buy complete "universal" pressure switches including the unloader valve in several different port configurations and pre-set pressures for as little as $9 on-line. Surely Chinese made and may be of dubious quality, but how wrong can you go for $9 (with free shipping!)!
- Jay
/ Adjusting Cut Off Pressure Of Air compressor?? #12
- Jay
My Craftsman compressor started leaking air at the pressure switch. Sears wanted IIRC over $100 for the part. I was ready to buy a new compressor when I asked a sales associate at Atwoods if they had pressure switches. They had a USA made one and Chinese one for $12 and 9 respectively. The Chinese one even had a cutoff switch but I got the USA one for a bit more money since I really didn't need the on/off switch since the receptacle is right by the compressor. Well a year later and the USA one was leaking air at the diaphragm gasket also so this time I replaced it with a Chinese one. Will have to see how long it lasts.
/ Adjusting Cut Off Pressure Of Air compressor?? #13
The pump is more than likely the limiting factor on the pressure limit. If it's an oil-less compressor than that is probably the reason. The seals on the piston of an oil-less compressor are one of the limiting factors when it comes to pressure limit. So lowering the limit may buy you a little more life out of the compressor. Tank is more than likely adequate to handle 125psi.
2017 Kubota M7-151 Premium MFWD Tractor (A61307)
2017 Kubota M7-151...
Deere 333G (A53317)
Deere 333G (A53317)
2025 SKLP SK-PSJ220 Electric Jaw Crusher (A59228)
2025 SKLP...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
Rockwood Freedom 1640LTD 18ft. Pop Up Camper Trailer (A59231)
Rockwood Freedom...
