Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #2,001
Lol....I knew it! You may be right about working through one size at a time....we'll see :)
/ Let's talk flail mowers #2,002
Well...newest member reporting in. Phoenix TE 79 showed up today. That's the good news. Bad news is freakin non-stop rain for the last week and forecast for the next week as well... I could probably get the truck and trailer out but getting it back in would be a circus. So, I wait...
Mark
Welcome to the flail Mower Nation Mark
________________________________________________________________________________________________
Once you go flail you never go back!!!!! :^)
Only 17,500 brush mowers to go+-
Pronovost or not at all!!!:drink:
/ Let's talk flail mowers #2,003
Had my first failure on my EFG155:
image by parkanzky
The screws holding the roller on worked themselves out. When the roller dropped, it sheared a grease fitting.
The screws were incredibly soft. I actually stripped one on the right side when I was torquing them down during the initial setup. So I am going to source a better grade of fastener and a couple new zirk fittings and get it back together.
image by parkanzky
I was pleasantly surprised at how well the bearings still turned and how round the drum still appears to be considering the stumps and big rocks I've gotten snagged on recently. Overall, the ultra-budget option is holding up really well, though the knives are all ridiculously dull. I can't decide whether to flip them all over and use them again for awhile or try to source a beefier option.
/ Let's talk flail mowers #2,004
How old is that mower?
/ Let's talk flail mowers #2,006
https://flic.kr/p/u1JaU2image by parkanzky
https://flic.kr/p/u1Jcy4image by parkanzky
That same thing happened to me a few months ago. I have a one year old Caroni. I ended up needing a new bering inside my roller. I also noted the soft bolts -- and had the same experience during assembly. It is all good now!
/ Let's talk flail mowers #2,007
image by parkanzky
I have a 1 year old EFG 145 that i wanted to tear down to clean and check the bearings, the rotor wouldn't come off once the side bearing blocks were unscrewed, that's where i noticed a significant buldge on each side of the mower where the rotor bearing blocks are fastened, after prying the rotor out of the mower with a floor jack (tried jumping on the protuding part in vain) i noticed one of the bearings was mounted backwards (in the right side bearing block), as a result the rotor assembly was 1cm (little less than half an inch) longer than the mower casing was wide, how can this happen is bewildering, it's not like they couldn't notice something was very wrong, there was so much pressure on the relatively strong side walls that it must have been a bear to aligne the bearing block holes to the casing pattern.
Bearings are still good though...
/ Let's talk flail mowers #2,008
I bought a well used JD 25a flail a few weeks ago. Decided to grease it and give it a test drive as-is and was very disappointed with the cut and performance overall. I just about put this mower in the garbage can but decided to spend the money for a new set of knives and related hardware. Swapped them out tonight and took it for a test drive, and wow what a difference!
The old knives weren't that bad but I'm absolutely amazed at the difference with the new knives. This thing actually performs like I thought it would (based on reading this thread) when I bought it. For any of you thinking about picking up a used flail I definitely recommend spending the coin for new knives as the improvement is significant.
/ Let's talk flail mowers #2,009
I bought a well used JD 25a flail a few weeks ago. Decided to grease it and give it a test drive as-is and was very disappointed with the cut and performance overall. I just about put this mower in the garbage can but decided to spend the money for a new set of knives and related hardware. Swapped them out tonight and took it for a test drive, and wow what a difference! The old knives weren't that bad but I'm absolutely amazed at the difference with the new knives. This thing actually performs like I thought it would (based on reading this thread) when I bought it. For any of you thinking about picking up a used flail I definitely recommend spending the coin for new knives as the improvement is significant.
How much was a set of blades? I'm currently looking at a JF 25A myself. Which I know nothing about. When I go to look at this, anything in particular you recommend I look at?
/ Let's talk flail mowers #2,010
I have a JD 25A mower. There are two types of blades for the 25a
This one is used for more of a finish cut
attachment.php
and this one cuts better in tall grass
attachment.php
Here is a newer type with iMatch compatibility
attachment.php
I have the older type without iMatch compatibility
attachment.php
  • jd_401_industrial_tractor__triumph_5__side___mount_mower__jd_25a__6__flail_mower_5_lgw.jpg
/ Let's talk flail mowers #2,011
Wow, ok. Here I thought the duck foot was called a hammer and more designed from brush and the the side type blades were meant for finish. Interesting. The next question, what is i match?
/ Let's talk flail mowers #2,012
I"m sure others on TBN know more about the John Deere iMatch Quick Hitch then I do, my understanding is that it allows the user to hook up 3 point implements without getting down off the tractor.
[video]http://www.deere.com/en_US/media/player/player.html?src=/cce/cuts_easeofuse/imatchautohitch/imatchautohitch_h.flv&autostart=true[/video]
/ Let's talk flail mowers #2,014
/ Let's talk flail mowers #2,020
Picked up these today <img src="http://www.tractorbynet.com/forums/files/attachments/429836-lets-talk-flail-mowers-image-3715905170-jpg"/>
Two "new to you" flails?? Nice. I see fresh grass one one. Is the second also functional?
2015 GMC Yukon XL Denali SUV (A64557)
2015 GMC Yukon XL...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2015 Mack CXU613 Tri-Axle Day Cab Truck Tractor (A64194)
2015 Mack CXU613...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
2023 Giddy Up USA 13ft. S/A Enclosed Cargo Trailer. (A64557)
2023 Giddy Up USA...
2025 48in. Farm Jack (A64553)
2025 48in. Farm...
